after upgrading my OH system to 2.5.0.M2 - Docker container on Synology NAS - my MQTT things worked fine. Yet out of the blue one of the things (ESPEasy powered WemosD1) is causing an error - see below. Any advice how to get this resolved? Do I need to delete and setup the thing and items again?
2019-09-05 07:42:07.721 [ERROR] [.moquette.broker.NewNettyMQTTHandler] - Error processing protocol message: SUBSCRIBE
java.lang.IllegalArgumentException: Could not deserialize [-84, -19, 0, 5, 115, 114, 0, 45, 105, 111, 46, 109, 111, 113, 117, 101, 116, 116, 101, 46, 98, 114, 111, 107, 101, 114, 46, 115, 117, 98, 115, 99, 114, 105, 112, 116, 105, 111, 110, 115, 46, 83, 117, 98, 115, 99, 114, 105, 112, 116, 105, 111, 110, -47, 11, -117, 54, 80, -6, 26, -58, 2, 0, 3, 76, 0, 8, 99, 108, 105, 101, 110, 116, 73, 100, 116, 0, 18, 76, 106, 97, 118, 97, 47, 108, 97, 110, 103, 47, 83, 116, 114, 105, 110, 103, 59, 76, 0, 12, 114, 101, 113, 117, 101, 115, 116, 101, 100, 81, 111, 115, 116, 0, 37, 76, 105, 111, 47, 110, 101, 116, 116, 121, 47, 104, 97, 110, 100, 108, 101, 114, 47, 99, 111, 100, 101, 99, 47, 109, 113, 116, 116, 47, 77, 113, 116, 116, 81, 111, 83, 59, 76, 0, 11, 116, 111, 112, 105, 99, 70, 105, 108, 116, 101, 114, 116, 0, 40, 76, 105, 111, 47, 109, 111, 113, 117, 101, 116, 116, 101, 47, 98, 114, 111, 107, 101, 114, 47, 115, 117, 98, 115, 99, 114, 105, 112, 116, 105, 111, 110, 115, 47, 84, 111, 112, 105, 99, 59, 120, 112, 116, 0, 20, 101, 109, 98, 101, 100,... [1.4.199/0]
at org.h2.mvstore.DataUtils.newIllegalArgumentException(DataUtils.java:857) ~[203:com.h2database.mvstore:1.4.199]
at org.h2.mvstore.type.ObjectDataType.deserialize(ObjectDataType.java:376) ~[203:com.h2database.mvstore:1.4.199]
at org.h2.mvstore.type.ObjectDataType$SerializedObjectType.read(ObjectDataType.java:1547) ~[203:com.h2database.mvstore:1.4.199]
at org.h2.mvstore.type.ObjectDataType.read(ObjectDataType.java:231) ~[203:com.h2database.mvstore:1.4.199]
at org.h2.mvstore.type.ObjectDataType.read(ObjectDataType.java:114) ~[203:com.h2database.mvstore:1.4.199]
at org.h2.mvstore.Page$Leaf.readPayLoad(Page.java:1551) ~[203:com.h2database.mvstore:1.4.199]
at org.h2.mvstore.Page.read(Page.java:695) ~[203:com.h2database.mvstore:1.4.199]
at org.h2.mvstore.Page.read(Page.java:238) ~[203:com.h2database.mvstore:1.4.199]
at org.h2.mvstore.MVStore.readPage(MVStore.java:2187) ~[203:com.h2database.mvstore:1.4.199]
at org.h2.mvstore.MVMap.readPage(MVMap.java:554) ~[203:com.h2database.mvstore:1.4.199]
at org.h2.mvstore.Page$NonLeaf.getChildPage(Page.java:1086) ~[203:com.h2database.mvstore:1.4.199]
at org.h2.mvstore.MVMap.traverseDown(MVMap.java:1877) ~[203:com.h2database.mvstore:1.4.199]
at org.h2.mvstore.MVMap.operate(MVMap.java:1664) ~[203:com.h2database.mvstore:1.4.199]
at org.h2.mvstore.MVMap.put(MVMap.java:151) ~[203:com.h2database.mvstore:1.4.199]
at io.moquette.persistence.H2SubscriptionsRepository.addNewSubscription(H2SubscriptionsRepository.java:41) ~[204:io.moquette.moquette-broker:0.12.1]
at io.moquette.broker.subscriptions.CTrieSubscriptionDirectory.add(CTrieSubscriptionDirectory.java:88) ~[204:io.moquette.moquette-broker:0.12.1]
at io.moquette.broker.PostOffice.subscribeClientToTopics(PostOffice.java:81) ~[204:io.moquette.moquette-broker:0.12.1]
at io.moquette.broker.MQTTConnection.processSubscribe(MQTTConnection.java:306) ~[204:io.moquette.moquette-broker:0.12.1]
at io.moquette.broker.MQTTConnection.handleMessage(MQTTConnection.java:70) ~[204:io.moquette.moquette-broker:0.12.1]
at io.moquette.broker.NewNettyMQTTHandler.channelRead(NewNettyMQTTHandler.java:58) [204:io.moquette.moquette-broker:0.12.1]
at io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(AbstractChannelHandlerContext.java:359) [211:io.netty.transport:4.1.34.Final]
at io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(AbstractChannelHandlerContext.java:345) [211:io.netty.transport:4.1.34.Final]
at io.netty.channel.AbstractChannelHandlerContext.fireChannelRead(AbstractChannelHandlerContext.java:337) [211:io.netty.transport:4.1.34.Final]
at io.moquette.broker.metrics.MQTTMessageLogger.channelRead(MQTTMessageLogger.java:46) [204:io.moquette.moquette-broker:0.12.1]
at io.moquette.broker.metrics.MessageMetricsHandler.channelRead(MessageMetricsHandler.java:50) [204:io.moquette.moquette-broker:0.12.1]
at io.netty.handler.codec.ByteToMessageDecoder.fireChannelRead(ByteToMessageDecoder.java:323) [206:io.netty.codec:4.1.34.Final]
at io.netty.handler.codec.ByteToMessageDecoder.channelRead(ByteToMessageDecoder.java:297) [206:io.netty.codec:4.1.34.Final]
at io.netty.channel.ChannelInboundHandlerAdapter.channelRead(ChannelInboundHandlerAdapter.java:86) [211:io.netty.transport:4.1.34.Final]
at io.moquette.broker.metrics.BytesMetricsHandler.channelRead(BytesMetricsHandler.java:51) [204:io.moquette.moquette-broker:0.12.1]
at io.netty.handler.timeout.IdleStateHandler.channelRead(IdleStateHandler.java:286) [209:io.netty.handler:4.1.34.Final]
at io.netty.channel.DefaultChannelPipeline$HeadContext.channelRead(DefaultChannelPipeline.java:1408) [211:io.netty.transport:4.1.34.Final]
at io.netty.channel.DefaultChannelPipeline.fireChannelRead(DefaultChannelPipeline.java:930) [211:io.netty.transport:4.1.34.Final]
at io.netty.channel.nio.AbstractNioByteChannel$NioByteUnsafe.read(AbstractNioByteChannel.java:163) [211:io.netty.transport:4.1.34.Final]
at io.netty.channel.nio.NioEventLoop.processSelectedKey(NioEventLoop.java:677) [211:io.netty.transport:4.1.34.Final]
at io.netty.channel.nio.NioEventLoop.processSelectedKeysOptimized(NioEventLoop.java:612) [211:io.netty.transport:4.1.34.Final]
at io.netty.channel.nio.NioEventLoop.processSelectedKeys(NioEventLoop.java:529) [211:io.netty.transport:4.1.34.Final]
at io.netty.channel.nio.NioEventLoop.run(NioEventLoop.java:491) [211:io.netty.transport:4.1.34.Final]
at io.netty.util.concurrent.SingleThreadEventExecutor$5.run(SingleThreadEventExecutor.java:905) [208:io.netty.common:4.1.34.Final]
at io.netty.util.concurrent.FastThreadLocalRunnable.run(FastThreadLocalRunnable.java:30) [208:io.netty.common:4.1.34.Final]
Caused by: java.lang.ClassNotFoundException: io.moquette.broker.subscriptions.Subscription cannot be found by com.h2database.mvstore_1.4.199
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:484) ~[?:?]
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:395) ~[?:?]
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:387) ~[?:?]
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:150) ~[?:?]
at java.lang.ClassLoader.loadClass(ClassLoader.java:357) ~[?:?]
at java.lang.Class.forName0(Native Method) ~[?:?]
at java.lang.Class.forName(Class.java:348) ~[?:?]
at java.io.ObjectInputStream.resolveClass(ObjectInputStream.java:686) ~[?:?]
at java.io.ObjectInputStream.readNonProxyDesc(ObjectInputStream.java:1868) ~[?:?]
at java.io.ObjectInputStream.readClassDesc(ObjectInputStream.java:1751) ~[?:?]
at java.io.ObjectInputStream.readOrdinaryObject(ObjectInputStream.java:2042) ~[?:?]
at java.io.ObjectInputStream.readObject0(ObjectInputStream.java:1573) ~[?:?]
at java.io.ObjectInputStream.readObject(ObjectInputStream.java:431) ~[?:?]
at org.h2.mvstore.type.ObjectDataType.deserialize(ObjectDataType.java:374) ~[?:?]
... 66 more
Thanks!
