HABApp-MQTT-Event-Bus
A MQTT Event Bus for openHAB 2.x and 3.x using HABApp. Tested with openHAB 3. This should work equivalent like the Event bus binding from the old MQTT 1.x binding.
Description:
Publish/receive all states/commmands directly on the openHAB eventbus.
Usage:
Perfect for integrating multiple openHAB instances or broadcasting all events.
Preparation
Install HABApp
At first you have to install HABApp.
Then I changed the permissions with
sudo chown -R openhab:openhab /opt/habapp
sudo chown -R openhab:openhab /etc/openhab/habapp
HABApp should also work with the permissions in the installations steps. However, my problem was that the log files were not created then.
If your are using openHAB 2 instead of openHAB 3 you have to use /etc/openhab2/habapp
instead of /etc/openhab/habapp
Also you have to make sure that the systemd file looks like following:
[Unit]
Description=HABApp
Documentation=https://habapp.readthedocs.io
After=openhab.service
[Service]
Type=simple
User=openhab
Group=openhab
UMask=002
ExecStart=/opt/habapp/bin/habapp -c /etc/openhab/habapp
[Install]
WantedBy=multi-user.target
So please make sure that User and Group are openhab because it could be that there will be not logs in /var/log/openhab2
or /var/log/openhab
Install the mosquitto MQTT broker
The next step is to install the mosquitto MQTT broker on the master with
sudo apt install mosquitto mosquitto-clients
The slaves only need mosquitto-clients
because all slaves will later be connected to the master.
Then you have to edit the mosquitto.conf file:
# Place your local configuration in /etc/mosquitto/conf.d/
# A full description of the configuration file is at
# /usr/share/doc/mosquitto/examples/mosquitto.conf.example
listener 1883 0.0.0.0
pid_file /run/mosquitto/mosquitto.pid
persistence true
persistence_location /var/lib/mosquitto/
log_dest file /var/log/mosquitto/mosquitto.log
include_dir /etc/mosquitto/conf.d
allow_anonymous true
Of course you can use a password which mean you should not have to use allow_anonymous true
. The more important thing is that you have to use listener 1883 0.0.0.0
. This means that the mosquitto broker will be public accessible for all slaves (maybe if you want with a password).
Configure HABapp
Configure the MQTT and openHAB connection
At first we will configure the config.yml
for HABApp:
directories:
logging: /var/log/openhab # Folder where the logs will be written to
rules: rules # Folder from which the rule files will be loaded
param: params # Folder from which the parameter files will be loaded
config: config # Folder from which configuration files (e.g. for textual thing configuration) will be loaded
lib: lib # Folder where additional libraries can be placed
latitude: 0.0
longitude: 0.0
elevation: 0.0
mqtt:
connection:
client_id: <client_name>
host: <public_ip_of_mosquitto_broker>
port: 1883
user: ''
password: ''
tls: false
tls_ca_cert: '' # Path to a CA certificate that will be treated as trusted
tls_insecure: true
general:
listen_only: false # If True HABApp will not publish any value to the broker
publish:
qos: 0 # Default QoS when publishing values
retain: false # Default retain flag when publishing values
subscribe:
qos: 0 # Default QoS for subscribing
topics:
- 0
openhab:
connection:
host: <public_ip_of_openhab_instance>
port: 8080
user: '<openhab_user>'
password: '<openhab_password>'
general:
listen_only: false # If True HABApp will not change anything on the openHAB instance.
wait_for_openhab: true # If True HABApp will wait for items from the openHAB instance before loading any rules on startup
ping:
enabled: true # If enabled the configured item will show how long it takes to send an update from HABApp and get the updated value back from openhabin milliseconds
item: HABApp_Ping # Name of the Numberitem
interval: 10 # Seconds between two pings
The <client_name>
can be random. On the master it could contain the word master and on the slave(s) it could be contain slave for separation. All openHAB instances should refer to the same public ip adress so <public_ip_of_mosquitto_broker>
should be always the same. As you seen in the mosquitto.conf
we use the public port 1883
so maybe you want to use 8883
or another port number.
If you all the anonymous access to the mosquitto broker user
and password
could be empty. If not fill in the username and password. I also changed tls
to false
and tls_insecure
to true
. Please check your mosquitto.conf
! If you will use tls then you have to set tls
to true
and tls_insecure
to false
In the openhab section you can use localhost
for <public_ip_of_openhab_instance>
because it will refer to the openhab instance you are currently using. For a better separation I used the public ip address. If you are using openHAB 3 you should replace <openhab_user>
and <openhab_password>
with the username and password you need to access the openHAB settings panel. If you are using openHAB 2 it could be that there is no username and password needed. Please check your openHAB configuration!
In the next step we will add following to the logging.yml
file:
MQTTEventBusHandler:
class: HABApp.core.lib.handler.MidnightRotatingFileHandler
filename: '/var/log/openhab/EventBus.log'
maxBytes: 1_048_576
backupCount: 3
formatter: Frontail_format
level: DEBUG
and
maxBytes: 1_048_576
backupCount: 3
level: DEBUG
Configure the logging handler
So in my case the config.yml
looks like this:
levels:
WARNING: WARN
formatters:
HABApp_format:
format: '[%(asctime)s] [%(name)25s] %(levelname)8s | %(message)s'
Frontail_format:
format: '%(asctime)s.%(msecs)03d [%(levelname)-5s] [%(name)-36s] - %(message)s'
datefmt: '%Y-%m-%d %H:%M:%S'
handlers:
# There are several Handlers available:
# - logging.handlers.RotatingFileHandler:
# Will rotate when the file reaches a certain size (see python logging documentation for args)
# - HABApp.core.lib.handler.MidnightRotatingFileHandler:
# Will wait until the file reaches a certain size and then rotate on midnight
# - More handlers:
# https://docs.python.org/3/library/logging.handlers.html#rotatingfilehandler
HABApp_default:
filename: '/var/log/openhab/HABApp.log'
maxBytes: 1_048_576
backupCount: 3
level: DEBUG
EventFile:
filename: 'HABApp_events.log'
maxBytes: 1_048_576
backupCount: 3
formatter: HABApp_format
level: DEBUG
BufferEventFile:
class: logging.handlers.MemoryHandler
capacity: 10
target: EventFile
level: DEBUG
maxBytes: 1_048_576
backupCount: 3
level: DEBUG
loggers:
HABApp:
level: INFO
handlers:
- HABApp_default
propagate: False
MQTTEventBus:
level: DEBUG
handlers:
- MQTTEventBusHandler
propagate: False
HABApp.EventBus:
level: INFO
handlers:
- BufferEventFile
propagate: False
This will add EventBus.log
file to '/var/log/openhab/
. If you are using openHAB 2 please make sure that the log file will be in /var/log/openhab2
Installation
You can install it for openHAB 3 with:
wget https://raw.githubusercontent.com/Michdo93/HABApp-MQTT-Event-Bus/main/mqtt_event_bus.py -P /etc/openhab/habapp/rules
sudo chmod +x /etc/openhab/habapp/rules/mqtt_event_bus.py
sudo chown -R openhab:openhab /etc/openhab/habapp/rules/mqtt_event_bus.py
And for openHAB 2 with:
wget https://raw.githubusercontent.com/Michdo93/HABApp-MQTT-Event-Bus/main/mqtt_event_bus.py -P /etc/openhab2/habapp/rules
sudo chmod +x /etc/openhab2/habapp/rules/mqtt_event_bus.py
sudo chown -R openhab:openhab /etc/openhab2/habapp/rules/mqtt_event_bus.py
or copy this code and create a file with sudo nano /etc/openhab/habapp/rules/mqtt_event_bus.py
or sudo nano /etc/openhab2/habapp/rules/mqtt_event_bus.py
import logging
import HABApp
from HABApp import Parameter
from HABApp.core.events import ValueChangeEvent, ValueUpdateEvent
from HABApp.mqtt.items import MqttItem
from HABApp.openhab.events import ItemCommandEvent, ItemStateEvent
from HABApp.openhab.items import OpenhabItem
log = logging.getLogger('MQTTEventBus')
# These are the configuration values that will be used to setup the MqttEventBus
log_state = Parameter('mqtt_event_bus', 'log_state', default_value=True).value
statePublishTopic = Parameter(
'mqtt_event_bus', 'statePublishTopic', default_value='').value
commandPublishTopic = Parameter(
'mqtt_event_bus', 'commandPublishTopic', default_value='').value
stateSubscribeTopic = Parameter(
'mqtt_event_bus', 'stateSubscribeTopic', default_value='').value
commandSubscribeTopic = Parameter(
'mqtt_event_bus', 'commandSubscribeTopic', default_value='').value
class MqttEventBus(HABApp.Rule):
def __init__(self):
super().__init__()
for item in self.get_items(type=OpenhabItem):
if statePublishTopic != '':
item.listen_event(self.on_item_state, ItemStateEvent)
if commandPublishTopic != '':
item.listen_event(self.on_item_command, ItemCommandEvent)
if commandSubscribeTopic != '':
topic_command = commandSubscribeTopic.replace(
"${item}", str(item.name))
mqtt_item_command = MqttItem.get_create_item(f'{topic_command}')
mqtt_item_command.listen_event(
self.on_mqtt_command, ValueUpdateEvent)
if stateSubscribeTopic != '':
topic_state = stateSubscribeTopic.replace(
mqtt_item_state = MqttItem.get_create_item(f'{topic_state}')
mqtt_item_state.listen_event(
self.on_mqtt_state, ValueUpdateEvent)
def on_mqtt_command(self, event):
assert isinstance(event, ValueUpdateEvent)
name = event.name
itemPosition = commandSubscribeTopic.split("${item}")[0].count("/")
item = name.split("/")[itemPosition]
cmd = event.value
log.info(f'Subscribed MQTT topic {event.name} with {cmd}')
log.info(f'{item} predicted to become {cmd}')
self.openhab.send_command(item, cmd)
def on_item_state(self, event: ItemStateEvent):
topicString = statePublishTopic.replace(
"${item}", event.name)
topic = f'{topicString}'
value = event.value
log.info(f'Published MQTT topic {topic} with {value}')
self.mqtt.publish(topic, str(value))
def on_item_command(self, event: ItemCommandEvent):
topicString = commandPublishTopic.replace(
value = event.value
def on_mqtt_state(self, event):
name = event.name
itemPosition = stateSubscribeTopic.split("${item}")[0].count("/")
state = event.value
log.info(f'Subscribed MQTT topic {name} with {state}')
self.openhab.post_update(item, state)
class LogItemStateRule(HABApp.Rule):
"""This rule logs the item state in the mqtt event bus log file"""
def __init__(self):
super().__init__()
item.listen_event(self.on_item_change, ValueChangeEvent)
def on_item_change(self, event):
assert isinstance(event, ValueChangeEvent)
log.info(f'{event.name} changed from {event.old_value} to {event.value}')
MqttEventBus()
# Create logger rule only if configured
if log_state:
LogItemStateRule()
After that you have to restart habapp with:
sudo systemctl restart habapp.service
This should create a file like this in /etc/openhab/habapp/params/mqtt_event_bus.yml
or /etc/openhab2/habapp/params/mqtt_event_bus.yml
log_state: true
statePublishTopic: ''
commandPublishTopic: ''
stateSubscribeTopic: ''
commandSubscribeTopic: ''
If not you can create it with sudo nano /etc/openhab/habapp/params/mqtt_event_bus.yml
or sudo nano /etc/openhab2/habapp/params/mqtt_event_bus.yml
. Alternatively you can download it with wget https://raw.githubusercontent.com/Michdo93/HABApp-MQTT-Event-Bus/main/mqtt_event_bus.yml -O /etc/openhab/habapp/params/mqtt_event_bus.yml
or wget https://raw.githubusercontent.com/Michdo93/HABApp-MQTT-Event-Bus/main/mqtt_event_bus.yml -O /etc/openhab2/habapp/params/mqtt_event_bus.yml
Master / Slave example
Please make sure that the slave(s) will be connected to the masterās mosquitto broker!
Usage
You have to make sure that the item names on the master and on the slave(s) are equal. The master should contain all items from all slaves. But not all slaves should contain all items from the master. This means that the slaves can have different items with different names. Also the slaves could have only a few items from the master. This can be thought of as a restricted user who only has access to a few items. For example, that a slave is in the bathroom and the openHAB instance in the bathroom then only allows the items in the bathroom to be operated. The master/slave principle can only subscribe where the corresponding item is present. Otherwise it will be published, but a slave or even none of the slaves will access this topic. Conversely, the master should be able to subscribe to everything that the slaves publish.
Configuration example 1
On the master you can create a configuration like this:
log_state: true
statePublishTopic: openHAB/in/${item}/state
commandSubscribeTopic: openHAB/out/${item}/command
and on the slave like this:
log_state: true
commandPublishTopic: openHAB/out/${item}/command
stateSubscribeTopic: openHAB/in/${item}/state
Or on the master you can download it with wget https://raw.githubusercontent.com/Michdo93/HABApp-MQTT-Event-Bus/main/example/mqtt_event_bus.yml.master1 -O /etc/openhab/habapp/params/mqtt_event_bus.yml
or wget https://raw.githubusercontent.com/Michdo93/HABApp-MQTT-Event-Bus/main/example/mqtt_event_bus.yml.master1 -O /etc/openhab2/habapp/params/mqtt_event_bus.yml
. On the slave you can download it with wget https://raw.githubusercontent.com/Michdo93/HABApp-MQTT-Event-Bus/main/example/mqtt_event_bus.yml.slave1 -O /etc/openhab/habapp/params/mqtt_event_bus.yml
or wget https://raw.githubusercontent.com/Michdo93/HABApp-MQTT-Event-Bus/main/example/mqtt_event_bus.yml.slave1 -O /etc/openhab2/habapp/params/mqtt_event_bus.yml
Configuration example 2
log_state: true
statePublishTopic: /messages/states/${item}
commandSubscribeTopic: /messages/commands/${item}
log_state: true
commandPublishTopic: /messages/commands/${item}
stateSubscribeTopic: /messages/states/${item}
Or on the master you can download it with wget https://raw.githubusercontent.com/Michdo93/HABApp-MQTT-Event-Bus/main/example/mqtt_event_bus.yml.master2 -O /etc/openhab/habapp/params/mqtt_event_bus.yml
or wget https://raw.githubusercontent.com/Michdo93/HABApp-MQTT-Event-Bus/main/example/mqtt_event_bus.yml.master2 -O /etc/openhab2/habapp/params/mqtt_event_bus.yml
. On the slave you can download it with wget https://raw.githubusercontent.com/Michdo93/HABApp-MQTT-Event-Bus/main/example/mqtt_event_bus.yml.slave2 -O /etc/openhab/habapp/params/mqtt_event_bus.yml
or wget https://raw.githubusercontent.com/Michdo93/HABApp-MQTT-Event-Bus/main/example/mqtt_event_bus.yml.slave2 -O /etc/openhab2/habapp/params/mqtt_event_bus.yml
Proof of concept
Check the master logging
The EventBus.log
on the master could look like this:
2021-12-04 00:35:02.326 [INFO ] [MQTTEventBus ] - Published MQTT topic /openHAB/in/testSwitch/state with ON
2021-12-04 00:35:02.332 [INFO ] [MQTTEventBus ] - testSwitch changed from OFF to ON
2021-12-04 00:35:09.845 [INFO ] [MQTTEventBus ] - Subscribed MQTT topic/openHAB/out/testSwitch/command with OFF
2021-12-04 00:35:09.846 [INFO ] [MQTTEventBus ] - testSwitch predicted to become OFF
2021-12-04 00:35:09.889 [INFO ] [MQTTEventBus ] - Published MQTT topic /openHAB/in/testSwitch/state with OFF
2021-12-04 00:35:09.894 [INFO ] [MQTTEventBus ] - testSwitch changed from ON to OFF
2021-12-04 00:35:16.777 [INFO ] [MQTTEventBus ] - Subscribed MQTT topic/openHAB/out/testSwitch/command with ON
2021-12-04 00:35:16.779 [INFO ] [MQTTEventBus ] - testSwitch predicted to become ON
2021-12-04 00:35:16.817 [INFO ] [MQTTEventBus ] - Published MQTT topic /openHAB/in/testSwitch/state with ON
2021-12-04 00:35:16.823 [INFO ] [MQTTEventBus ] - testSwitch changed from OFF to ON
2021-12-04 00:35:20.787 [INFO ] [MQTTEventBus ] - Published MQTT topic /openHAB/in/testSwitch/state with OFF
2021-12-04 00:35:20.792 [INFO ] [MQTTEventBus ] - testSwitch changed from ON to OFF
Check the slave logging
The EventBus.log
on the slave(s) could look like this:
2021-12-04 00:35:02.337 [INFO ] [MQTTEventBus ] - Subscribed MQTT topic /openHAB/in/testSwitch/state with ON
2021-12-04 00:35:02.396 [INFO ] [MQTTEventBus ] - testSwitch changed from OFF to ON
2021-12-04 00:35:09.837 [INFO ] [MQTTEventBus ] - Published MQTT topic /openHAB/out/testSwitch/command with OFF
2021-12-04 00:35:09.847 [INFO ] [MQTTEventBus ] - testSwitch changed from ON to OFF
2021-12-04 00:35:09.893 [INFO ] [MQTTEventBus ] - Subscribed MQTT topic /openHAB/in/testSwitch/state with OFF
2021-12-04 00:35:16.767 [INFO ] [MQTTEventBus ] - Published MQTT topic /openHAB/out/testSwitch/command with ON
2021-12-04 00:35:16.781 [INFO ] [MQTTEventBus ] - testSwitch changed from OFF to ON
2021-12-04 00:35:16.821 [INFO ] [MQTTEventBus ] - Subscribed MQTT topic /openHAB/in/testSwitch/state with ON
2021-12-04 00:35:20.792 [INFO ] [MQTTEventBus ] - Subscribed MQTT topic /openHAB/in/testSwitch/state with OFF
2021-12-04 00:35:20.831 [INFO ] [MQTTEventBus ] - testSwitch changed from ON to OFF
