Platform information:
- Hardware: DiskStation 1511+
- OS: 6.2.2
- Java Runtime Environment: Java SE Development Kit 8u212
- openHAB version: 2.4.0
So I’ve been using LWT to determine when my devices are back online, this mostly work but about 20% of the time, I’ll get an exception in the log rather than have my rule fired.
String Test_Light_LWT "LWT" {channel="mqtt:topic:embedded-mqtt-broker:Test_Light_Thing:Test_Light_Channel_LWT"}
rule "Test LWT Changed"
Item Test_Light_LWT changed to "Online"
logInfo("Test LWT Changed", "Online: " + triggeringItem.name);
And the exception:
[ERROR] [quette.server.netty.NettyMQTTHandler] - Unexpected exception while processing MQTT message. Closing Netty channel. CId=DVES_A36693
java.io.IOException: Connection reset by peer
at sun.nio.ch.FileDispatcherImpl.read0(Native Method) ~[?:?]
at sun.nio.ch.SocketDispatcher.read(SocketDispatcher.java:39) ~[?:?]
at sun.nio.ch.IOUtil.readIntoNativeBuffer(IOUtil.java:223) ~[?:?]
at sun.nio.ch.IOUtil.read(IOUtil.java:192) ~[?:?]
at sun.nio.ch.SocketChannelImpl.read(SocketChannelImpl.java:380) ~[?:?]
at io.netty.buffer.PooledUnsafeDirectByteBuf.setBytes(PooledUnsafeDirectByteBuf.java:288) ~[236:org.eclipse.smarthome.io.mqttembeddedbroker:0.10.0.oh240]
at io.netty.buffer.AbstractByteBuf.writeBytes(AbstractByteBuf.java:1108) ~[236:org.eclipse.smarthome.io.mqttembeddedbroker:0.10.0.oh240]
at io.netty.channel.socket.nio.NioSocketChannel.doReadBytes(NioSocketChannel.java:345) ~[236:org.eclipse.smarthome.io.mqttembeddedbroker:0.10.0.oh240]
at io.netty.channel.nio.AbstractNioByteChannel$NioByteUnsafe.read(AbstractNioByteChannel.java:126) [236:org.eclipse.smarthome.io.mqttembeddedbroker:0.10.0.oh240]
at io.netty.channel.nio.NioEventLoop.processSelectedKey(NioEventLoop.java:645) [236:org.eclipse.smarthome.io.mqttembeddedbroker:0.10.0.oh240]
at io.netty.channel.nio.NioEventLoop.processSelectedKeysOptimized(NioEventLoop.java:580) [236:org.eclipse.smarthome.io.mqttembeddedbroker:0.10.0.oh240]
at io.netty.channel.nio.NioEventLoop.processSelectedKeys(NioEventLoop.java:497) [236:org.eclipse.smarthome.io.mqttembeddedbroker:0.10.0.oh240]
at io.netty.channel.nio.NioEventLoop.run(NioEventLoop.java:459) [236:org.eclipse.smarthome.io.mqttembeddedbroker:0.10.0.oh240]
at io.netty.util.concurrent.SingleThreadEventExecutor$5.run(SingleThreadEventExecutor.java:886) [236:org.eclipse.smarthome.io.mqttembeddedbroker:0.10.0.oh240]
at io.netty.util.concurrent.FastThreadLocalRunnable.run(FastThreadLocalRunnable.java:30) [236:org.eclipse.smarthome.io.mqttembeddedbroker:0.10.0.oh240]
I don’t think I can do much about it as this seems to be more of an internal issue. When this occurs, I don’t get the message in the log (rule not triggered) which is what I’m after. Any info on the subject would be greatly appreciated!
Nic
