I have a MQTT connection setup to my Roomba; I’ve noticed when I push a rule which I have logic in the rules not to execute during this push that the MQTT WiFi rule is getting executed very second.
Please ignore the “Script Interrupter can’t be obtain” - this is by design.
2019-10-09 13:23:54.425 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Roomba Wifi Stat JSON Received Update': Script interpreter couldn't be obtain
2019-10-09 13:23:54.426 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Roomba Wifi Stat JSON Received Update': Script interpreter couldn't be obtain
2019-10-09 13:23:54.427 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Roomba Wifi Stat JSON Received Update': Script interpreter couldn't be obtain
2019-10-09 13:23:54.428 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Roomba Wifi Stat JSON Received Update': Script interpreter couldn't be obtain
2019-10-09 13:23:54.429 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Roomba Wifi Stat JSON Received Update': Script interpreter couldn't be obtain
2019-10-09 13:23:54.430 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Roomba Wifi Stat JSON Received Update': Script interpreter couldn't be obtain
2019-10-09 13:23:54.431 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Roomba Wifi Stat JSON Received Update': Script interpreter couldn't be obtain
2019-10-09 13:23:54.432 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Roomba Wifi Stat JSON Received Update': Script interpreter couldn't be obtain
How can I slow down the MQTT traffic and/or rule firing?
Thing:
Bridge mqtt:broker:roomba "Roomba Main Floor" @ "Main Floor" [ clientID="xxxxx", host="192.168.0.143", port=8883, secure=true, username="xxxxx", password=":1:1531533625:xxxxx", certificatepin=false, publickeypin=false ]
Thing topic state "Roomba Cleaner State" @ "Main Floor" {
Channels:
Type string : wifistat "WiFi" [ stateTopic="wifistat" ]
Type string : shadow "Status" [ stateTopic="$aws/things/xxxxxx/shadow/#" ]
Item:
String RoombaWifistatJSON "Main Roomba WiFi [%s]" { channel="mqtt:topic:roomba:state:wifistat" }
Rule:
rule "Roomba Wifi Stat JSON Received Update"
Item RoombaWifistatJSON received update
if (systemStarted.state != ON) {
var String json = RoombaWifistatJSON.state.toString
if (systemStarted.state != ON && json !== null && json != NULL && json != UNDEF) {
for (String key: transform("JS", "roomba.js", json).split(",")) {
if (key == "localtimeoffset") {
} else if (key == "mac") {
} else if (key == "netinfo") {
} else if (key == "signal") {
} else if (key == "pose") {
} else if (key == "utctime") {
} else if (key == "wifistat") {
} else if (key == "wlcfg") {
} else {
logInfo("Roomba Wifi - Untagged Variable : ", "Roomba JSON: " + json + " Key: " + key)
Just trying to reduce the excess traffic; I’d be happy with once a minute OR 5 minutes.
Best, Jay
