For some reason I could not pinpoint where and how to resolve this issue I’m getting from the MQTT binding.
2021-12-04 22:25:20.437 [WARN ] [ab.binding.mqtt.generic.ChannelState] - Command ’ OFF ’ not supported by type ‘OnOffValue’: No enum constant org.openhab.core.library.types.OnOffType. OFF
2021-12-04 22:25:20.442 [WARN ] [ab.binding.mqtt.generic.ChannelState] - Command ’ OFF ’ not supported by type ‘OnOffValue’: No enum constant org.openhab.core.library.types.OnOffType. OFF
2021-12-04 22:25:20.448 [WARN ] [ab.binding.mqtt.generic.ChannelState] - Command ’ OFF ’ not supported by type ‘OnOffValue’: No enum constant org.openhab.core.library.types.OnOffType. OFF
2021-12-04 22:25:20.449 [WARN ] [ab.binding.mqtt.generic.ChannelState] - Command ’ OFF ’ not supported by type ‘OnOffValue’: No enum constant org.openhab.core.library.types.OnOffType. OFF
2021-12-04 22:25:20.458 [WARN ] [ab.binding.mqtt.generic.ChannelState] - Command ’ OFF ’ not supported by type ‘OnOffValue’: No enum constant org.openhab.core.library.types.OnOffType. OFF
The thing that I noticed is the spaces in between the ’ OFF ’ command. And this warning log only shows up after ring-mqtt items were recently added.
Thank you in advance for your input.
