Hello together,
i have an issue and i can’t find any solution for it.
OH3.1.0 is in use.
Error:
2021-10-17 17:17:24.746 [WARN ] [rnal.handler.GenericMQTTThingHandler] - Channel configuration error
java.lang.IllegalArgumentException: No enum constant org.openhab.binding.mqtt.generic.mapping.ColorMode.
at java.lang.Enum.valueOf(Enum.java:240) ~[?:?]
at org.openhab.binding.mqtt.generic.mapping.ColorMode.valueOf(ColorMode.java:1) ~[bundleFile:?]
at org.openhab.binding.mqtt.generic.values.ValueFactory.createValueState(ValueFactory.java:62) ~[bundleFile:?]
at org.openhab.binding.mqtt.generic.internal.handler.GenericMQTTThingHandler.initialize(GenericMQTTThingHandler.java:164) [bundleFile:?]
at org.openhab.core.thing.binding.BaseThingHandler.thingUpdated(BaseThingHandler.java:152) [bundleFile:?]
at jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at java.lang.reflect.Method.invoke(Method.java:566) ~[?:?]
at org.openhab.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:154) [bundleFile:?]
at org.openhab.core.internal.common.Invocation.call(Invocation.java:52) [bundleFile:?]
2021-10-17 17:17:24.781 [WARN ] [rnal.handler.GenericMQTTThingHandler] - Channel configuration error
Config:
- id: KugelFarbe
channelTypeUID: mqtt:color
label: KugelFarbe
description: “”
configuration: {}
I don’t add a topic. I create only the channel and get this error immediately.
And the thing stops working:
Swen
