MQTT - How to ignore out of range updates
I have the following thing:
Thing mqtt:topic:mosquitto: AC "AC" (mqtt:broker:mosquitto) []
  Type number : TargetTemp "Target Temperature"  [ stateTopic="AC/target_temperature/state", commandTopic="AC/target_temperature/command", unit="°C"]
Most of the time the updates are between 16 to 34. The problem starts when occasionally the update is NaN.
I would like to create a transformationPattern that ignores such updates and keeps the previous value.
what happened when it received NaN?
Do you need a range filter, which accepts input of, say, 10, or 100, or do you need numeric validation filter, which will accept 10 and 100 but rejects NaN?
I haven’t tested it but I’d imagine NaN wouldn’t be accepted by the mqtt binding anyway?
mqtt has min and max options.
Thanks, I am getting bellow warning::
 [WARN ] [ab.binding.mqtt.generic.ChannelState] - Incoming payload 'nan' not supported by type 'NumberValue'
The best result will be a numeric validation filter, which will accept numbers between 16 to 32, but rejects NaN or any other values.
You could use REGEX:\d+ (if you don’t receive decimal points) which would silence the NaN warning. REGEX:\d+(\.\d+)? to allow decimal points. Use min/max options to filter out unwanted range if required, but that’s a separate thing.
Thanks, where do I put the REGEX?
I tried to add it to the channel:
Type number : TargetTemp "Target Temperature"  [ stateTopic="AC/target_temperature/state", commandTopic="AC/target_temperature/command", unit="°C", transformationPattern="REGEX:(\d+)"]
But I got below error:
[WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model 'mqtt.things' has errors, therefore ignoring it: [165,264]: mismatched character 'd' expecting set null
Try REGEX:(\\d+) (two backslashes)
