MQTT - How to parse this data
Hello everyone,
I have a MQTT channel that I’m unsure how to add a channel to get this value (or an item from that channel).
The channel publish value
{“critical”: true}
I guess it could have other value. It seems to be json. How can I have an item (and channel) to read that value?
Like an item that would be critical on/off based on the true/false of the critical here.
Thank you!
Given that the only values are true and false the easy way is to use incomming transformation:
UID: mqtt:topic:test
label: Generic MQTT Thing
thingTypeUID: mqtt:topic
configuration: {}
bridgeUID: mqtt:broker:mosquitto
channels:
  - id: critical
    channelTypeUID: mqtt:switch
    label: Critical
    description: ""
    configuration:
      stateTopic: my/topic
      transformationPattern: JSONPATH:$.critical
      off: "false"
      on: "true"
You have to install jsonPath transformation service to get this channel working.
AH! JSONTPATH transformation, I forgot about that one. Just tried $.critical in the item using the gui and it worked.
Thank you!
