Hi folks,
I have mqtt setup and working. My switch sends a message ok.
To make my milights work I need to send the following:
lights/0x9B55/rgbw/3 with a payload of {“status”:“ON”}
I have an item as follows:Switch myItem { mqtt=">[mqtt:lights/0x9B55/rgbw/3:command:{“status”:“ON”}:1],>[mqtt:lights/0x9B55/rgbw/3:command:{“status”:“OFF”}:0]" }
clearly that, and any permutations, do not work.
I have tried the following:
Switch myItem { mqtt=">[mqtt:lights/0x9B55/rgbw/3:MAP(milight.map):1],>[mqtt:lights/0x9B55/rgbw/3:MAP(milight.map):0]" }
I have a map called milight.map which contains the following:
1={“status”:“ON”}
0={“status”:“OFF”}
None of the above works and I have run out of things to read and differences to try.
Any help appreciated.
Thanks!
