[SOLVED] MQTT item parsing
I try to parse MQTT message coming from domoticz (topic domoticz/out)
The content of the messages is JSON
Examples :
2015-10-01 21:54:25,493 INFO [log] {
“Battery” : 100,
“RSSI” : 12,
“dtype” : “Temp”,
“id” : “3073”,
“idx” : 45,
“name” : “Temperature”,
“nvalue” : 0,
“stype” : “TFA 30.3133”,
“svalue1” : “22.8”,
“unit” : 1
2015-10-01 21:54:25,473 INFO [log] {
“Battery” : 100,
“RSSI” : 12,
“dtype” : “Lux”,
“id” : “0000C03”,
“idx” : 44,
“name” : “Luminosite”,
“nvalue” : 0,
“stype” : “Lux”,
“svalue1” : “30”,
“unit” : 255
In my Item, I want to get the svalue1 of sensor name “Luminosite”
I defined it like that:
String LuminositeSensor “Luminosité [%s]” (g1) {mqtt="<[mqttserver:domoticz/out:state:JSONPATH($.svalue1):REGEX(.*“Luminosite”.*)]"}
But I didn’t success in filtering the correponding message, it is skipped…
2015-10-02 00:00:01.574 [DEBUG] [.o.b.m.i.MqttMessageSubscriber] - Skipped message '{
“Battery” : 100,
“RSSI” : 12,
“dtype” : “Lux”,
“id” : “0000C03”,
“idx” : 44,
“nvalue” : 0,
“stype” : “Lux”,
“svalue1” : “20”,
“unit” : 255
’ because Message Filter ‘REGEX(.*“Luminosite”.*)’ does not apply.
despite the regex pattern seems to match …
https://regex101.com/r/nG0eL9/27
any idea of how to define the mqtt binding rule to filter the correct sensor ?
Romain
I tested with a java regex parser :
http://www.regexplanet.com/advanced/java/index.html
My new REGEX : [\\s\\S](“Luminosite”)[\\s\\S]
It matches on the test page but not within the MQTT binding…
Where am I wrong ?
Found the response.
In fact, you don’t have to key the REGEX() word for the 5th parameter. You just have to key the REGEX rules directly.
String	LuminositeSensor "Luminosité [%s]"	(g1)	{mqtt="<[mqttserver:domoticz/out:state:JSONPATH($.svalue1):.*\"Luminosite\".*]"}
The sample in the wiki make me the mistake.
Could you post the link? I’m trying to integrate an ambient temperature sensor but have had no luck so far. Maybe with the document you used I could fix it? I’ve made a topic describing my problem here: [SOLVED] JSONpath doesn’t have enough parameters?
