Mqtt item slider
i have a problem with an inbound mqtt topic from an external dimmer.
My item is
Dimmer Deckenlicht_Couch_Dim “Wohnzimmer Deckenlicht Couch Dim [%d %%]” {mqtt=">[mosquitto:edomi/in/set/Wohnzimmer/Licht/Deckenlicht_Couch_dw:command::default], <[mosquitto:edomi/out/status/Wohnzimmer/Licht/Deckenlicht_Couch_RMw:state::default]", autoupdate=“false” }
here is the karaff log
log:tail org.openhab.binding.mqtt
21:58:36.229 [DEBUG] [g.mqtt.internal.MqttMessageSubscriber] - Skipped message '20
’ because Message Filter ‘default’ does not apply.
what im doing wrong.
I tried everthing.
You have an extra : between state and default. There should only be one. This problem exists in both MQTT configs.
Hi thx for your answer.
unfortunatly thats a copy paste error.
Here is my items file:
Dimmer	Deckenlicht_Couch_Dim	"Wohnzimmer Deckenlicht Couch Dim [%d %%]"	{mqtt=">[mosquitto:edomi/in/set/Wohnzimmer/Licht/Deckenlicht_Couch_dw:command:*:default], <[mosquitto:edomi/out/status/Wohnzimmer/Licht/Deckenlicht_Couch_RMw:state:*:default]", autoupdate="false" }
The outboud message works as aspected.
Only inbound is the problem.
Use this:
Dimmer	Deckenlicht_Couch_Dim	"Wohnzimmer Deckenlicht Couch Dim [%d %%]"	{mqtt=">[mosquitto:edomi/in/set/Wohnzimmer/Licht/Deckenlicht_Couch_dw:command:*:default], <[mosquitto:edomi/out/status/Wohnzimmer/Licht/Deckenlicht_Couch_RMw:state:default]", autoupdate="false" }
The inbound syntax is different from the outbound: broker:topic:state:default no * needed
Th alot!
but i found a “better way” for me with another problem :wink:
maybe someone could give me hint.
Heres my actual item
Dimmer	Deckenlicht_Couch_Dim	"Wohnzimmer Deckenlicht Couch Dim [%.1f %%]"	{mqtt=">[mosquitto:edomi/in/set/Wohnzimmer/Licht/Deckenlicht_Couch_dw:command:*:JS(convert-dim.js)], <[mosquitto:edomi/out/status/Wohnzimmer/Licht/Deckenlicht_Couch_RMw:state:JS(convert-dim-in.js)]", autoupdate="false" }
Here is my convert-dim-in.js transformation
(function(i) {
    if(input >= 0)
        return input / 255 * 100 ;
    else
        return null;
})(input)
I use this because my inbound topic is a dimmer that sends at 100% a Value of 255.
Here is the problem:
If I receive a payload of 128 I get something like this: 50,19607843137255
how could i change to a integer?
Do I have to modify the “js convert” or is this a rule?
return (input / 255 * 100).floor()
Hi thx. but i couldn’t get it to work.
I get
20:50:24.092 [ERROR] [g.mqtt.internal.MqttMessageSubscriber] - Error processing MQTT message.
org.openhab.core.transform.TransformationException: An error occurred while executing script.
i modified the js transformation like this
(function(i) {
    if(input >= 0)
        return (input / 255 * 100).floor() ;
    else
        return null;
})(input)
:flushed:
Hi I think i get it
here is my js code
(function(i) {
    if(input >= 0)
        return Math.floor(input / 255 * 100);
    else
        return null;
})(input)
thx alot for helping!!!
