MQTT items killing next item line
I’m sure I am just missing something small here, but when I put MQTT subscribed items in my items file, the next line after the MQTT line isn’t recognized unless I add a > after the line… I am super green at this, google searching hasn’t helped me yet, I attached 2 screenshots of the problem, one with the symbols and one without to help understand what I am describing. Either way it crashes my UI if I try and include those items in a sitemap…
Use the ESHD or Visual Studio Code plugin to find any syntax errors in your text files:
http://docs.openhab.org/configuration/editors.html
Thanks, it was something in the copy/paste not working right, manually typed the code and it works fine, lines are still the wrong colors, but it works.
