Spent a fair amount of time trying to do something simple. I get a MQTT moisture reading and I want to have items for the raw value and a percentage calculation.
Number Mqtt_PyPortal_Garage_moisture "Garage Portal" (gMoisture) {channel="mqtt:topic:mosquitto:PyPortal_Garage:moisture"}
Number Mqtt_PyPortal_Garage_moisture_percent "Garage Portal" (gMoisture) {channel="mqtt:topic:mosquitto:PyPortal_Garage:moisture"[profile="transform:JS", function="serialHumidity.js",sourceFormat="%.3f"]}
I’ve tried different source formats…
the javascript looks like this:
(function(i) {
i = i - 300
i = i / 700 * 100
return i;
})(input)
I’ve simplified the javascript for testing - don’t worry about the values or script name. The incoming channel is a number.
I get errors like these:
2020-12-05 11:31:56.185 [WARN ] [iles.JavascriptTransformationProfile] - Could not transform state '522' with function 'serialHumidity.js' and format '%.0f'
2020-12-05 11:35:09.249 [WARN ] [iles.JavascriptTransformationProfile] - Could not transform state ‘524’ with function ‘serialHumidity.js’ and format ‘%.3f’
2020-12-05 11:40:04.570 [WARN ] [iles.JavascriptTransformationProfile] - Could not transform state ‘524’ with function ‘serialHumidity.js’ and format ‘%.3f’
Can you show us the full MQTT message that you’re receiving? I suspect this has something to do with Javascript transforms only working with strings, so your i in your Javascript is a string, and needs to first be transformed into a Javascript number, I think…or is it that the Javascript Transformation can only return a string…can’t remember!
Thanks - I’m just using MQTT.FX to send the integer to the MQTT path. I was not aware of the string issue so I’ll tinker with that. Sending the value in MQTT as an integer…
I’m trying to back all the way to the beginning with string values and build up from there, step by step…
Yeah, it works just like I’d want it to if I leave the item as a string type.
If I want to have the item be a Number type, it seems like I need to use a rule.
Was just trying to keep this neat.
Am I missing something?
It will be used to trigger some routines based on measurements. I realize I can convert it to a number as needed but that will probably cause other problems. I guess if I’m going to write some rules around it I’ll do a transformation in a rule.
