OK, I figured I would have to sanitize it⊠there actually isnât anything I canât share. You know already but I have to say it for others later, this is mostly NOT my work, itâs swicagoâs script that I modified:
#include <ESP8266WiFi.h>
#include <ArduinoJson.h>
#include <PubSubClient.h>
#include <HeatPump.h>
#include "mitsubishi_heatpump_mqtt_esp8266.h"
#ifdef OTA
#include <ESP8266mDNS.h>
#include <ArduinoOTA.h>
#endif
// wifi, mqtt and heatpump client instances
WiFiClient espClient;
PubSubClient mqtt_client(espClient);
HeatPump hp;
unsigned long lastTempSend;
unsigned long lastRemoteTemp; //holds last time a remote temp value has been received from OpenHAB
unsigned long wifiMillis; //holds millis for counting up to hard reset for wifi reconnect
// debug mode, when true, will send all packets received from the heatpump to topic heatpump_debug_topic
// this can also be set by sending "on" to heatpump_debug_set_topic
bool _debugMode = false;
bool retain = true; //change to false to disable mqtt retain
void setup() {
pinMode(redLedPin, OUTPUT);
digitalWrite(redLedPin, HIGH);
pinMode(blueLedPin, OUTPUT);
digitalWrite(blueLedPin, HIGH);
WIFIConnect(); //connect to wifi
// configure mqtt connection
mqtt_client.setServer(mqtt_server, mqtt_port);
mqtt_client.setCallback(mqttCallback);
//mqttConnect(); //this is now called during loop
// connect to the heatpump. Callbacks first so that the hpPacketDebug callback is available for connect()
hp.setSettingsChangedCallback(hpSettingsChanged);
hp.setStatusChangedCallback(hpStatusChanged);
hp.setPacketCallback(hpPacketDebug);
#ifdef OTA
ArduinoOTA.begin();
#endif
hp.connect(&Serial);
lastTempSend = millis();
lastRemoteTemp = millis();
void hpSettingsChanged() {
const size_t bufferSize = JSON_OBJECT_SIZE(6);
DynamicJsonBuffer jsonBuffer(bufferSize);
JsonObject& root = jsonBuffer.createObject();
heatpumpSettings currentSettings = hp.getSettings();
root["power"] = currentSettings.power;
root["mode"] = currentSettings.mode;
root["temperature"] = hp.CelsiusToFahrenheit(currentSettings.temperature); //convert HP's C to usable F
root["fan"] = currentSettings.fan;
root["vane"] = currentSettings.vane;
root["wideVane"] = currentSettings.wideVane;
root["iSee"] = currentSettings.iSee;
char buffer[512];
root.printTo(buffer, sizeof(buffer));
if(!mqtt_client.publish(heatpump_topic, buffer, retain)) {
mqtt_client.publish(heatpump_debug_topic, "failed to publish to heatpump topic");
void hpStatusChanged(heatpumpStatus currentStatus) {
// send room temp and operating info
const size_t bufferSizeInfo = JSON_OBJECT_SIZE(2);
DynamicJsonBuffer jsonBufferInfo(bufferSizeInfo);
JsonObject& rootInfo = jsonBufferInfo.createObject();
//rootInfo["roomTemperature"] = currentStatus.roomTemperature;
rootInfo["roomTemperature"] = hp.CelsiusToFahrenheit(currentStatus.roomTemperature); //convert HP's c to usable F
rootInfo["operating"] = currentStatus.operating;
char bufferInfo[512];
rootInfo.printTo(bufferInfo, sizeof(bufferInfo));
if(!mqtt_client.publish(heatpump_status_topic, bufferInfo, true)) {
mqtt_client.publish(heatpump_debug_topic, "failed to publish to room temp and operation status to heatpump/status topic");
// send the timer info
// const size_t bufferSizeTimers = JSON_OBJECT_SIZE(5);
// DynamicJsonBuffer jsonBufferTimers(bufferSizeTimers);
// JsonObject& rootTimers = jsonBufferTimers.createObject();
// rootTimers["mode"] = currentStatus.timers.mode;
// rootTimers["onMins"] = currentStatus.timers.onMinutesSet;
// rootTimers["onRemainMins"] = currentStatus.timers.onMinutesRemaining;
// rootTimers["offMins"] = currentStatus.timers.offMinutesSet;
// rootTimers["offRemainMins"] = currentStatus.timers.offMinutesRemaining;
// char bufferTimers[512];
// rootTimers.printTo(bufferTimers, sizeof(bufferTimers));
// if(!mqtt_client.publish(heatpump_timers_topic, bufferTimers, true)) {
// mqtt_client.publish(heatpump_debug_topic, "failed to publish timer info to heatpump/status topic");
void hpPacketDebug(byte* packet, unsigned int length, char* packetDirection) {
if (_debugMode) {
String message;
for (int idx = 0; idx < length; idx++) {
if (packet[idx] < 16) {
message += "0"; // pad single hex digits with a 0
message += String(packet[idx], HEX) + " ";
const size_t bufferSize = JSON_OBJECT_SIZE(1);
root[packetDirection] = message;
char buffer[512];
if(!mqtt_client.publish(heatpump_debug_topic, buffer)) {
mqtt_client.publish(heatpump_debug_topic, "failed to publish to heatpump/debug topic");
void mqttCallback(char* topic, byte* payload, unsigned int length) {
// Copy payload into message buffer
char message[length + 1];
for (int i = 0; i < length; i++) {
message[i] = (char)payload[i];
message[length] = '\0';
if (strcmp(topic, heatpump_set_topic) == 0) { //if the incoming message is on the heatpump_set_topic topic...
// Parse message into JSON
JsonObject& root = jsonBuffer.parseObject(message);
if (!root.success()) {
mqtt_client.publish(heatpump_debug_topic, "!root.success(): invalid JSON on heatpump_set_topic...");
return;
// Step 3: Retrieve the values
if (root.containsKey("power")) {
String power = root["power"];
hp.setPowerSetting(power);
if (root.containsKey("mode")) {
String mode = root["mode"];
hp.setModeSetting(mode);
if (root.containsKey("temperature")) {
float temperature = root["temperature"];
//hp.setTemperature(temperature);
hp.setTemperature( hp.FahrenheitToCelsius(temperature) ); //set usable F to HP's stupid C
if (root.containsKey("fan")) {
String fan = root["fan"];
hp.setFanSpeed(fan);
if (root.containsKey("vane")) {
String vane = root["vane"];
hp.setVaneSetting(vane);
if (root.containsKey("wideVane")) {
String wideVane = root["wideVane"];
hp.setWideVaneSetting(wideVane);
if(root.containsKey("remoteTemp")) {
float remoteTemp = root["remoteTemp"];
//hp.setRemoteTemperature(remoteTemp);
hp.setRemoteTemperature( hp.FahrenheitToCelsius(remoteTemp) ); //set usable F to HP's stupid C
else if (root.containsKey("custom")) {
String custom = root["custom"];
// copy custom packet to char array
char buffer[(custom.length() + 1)]; // +1 for the NULL at the end
custom.toCharArray(buffer, (custom.length() + 1));
byte bytes[20]; // max custom packet bytes is 20
int byteCount = 0;
char *nextByte;
// loop over the byte string, breaking it up by spaces (or at the end of the line - \n)
nextByte = strtok(buffer, " ");
while (nextByte != NULL && byteCount < 20) {
bytes[byteCount] = strtol(nextByte, NULL, 16); // convert from hex string
nextByte = strtok(NULL, " ");
byteCount++;
// dump the packet so we can see what it is. handy because you can run the code without connecting the ESP to the heatpump, and test sending custom packets
hpPacketDebug(bytes, byteCount, "customPacket");
hp.sendCustomPacket(bytes, byteCount);
else {
bool result = hp.update();
if (!result) {
mqtt_client.publish(heatpump_debug_topic, "heatpump: update() failed");
} else if (strcmp(topic, heatpump_debug_set_topic) == 0) { //if the incoming message is on the heatpump_debug_set_topic topic...
if (strcmp(message, "on") == 0) {
_debugMode = true;
mqtt_client.publish(heatpump_debug_topic, "debug mode enabled");
} else if (strcmp(message, "off") == 0) {
_debugMode = false;
mqtt_client.publish(heatpump_debug_topic, "debug mode disabled");
} else {
mqtt_client.publish(heatpump_debug_topic, strcat("heatpump: wrong mqtt topic: ", topic));
void mqttConnect() {
// Loop until we're reconnected
while (!mqtt_client.connected()) {
// Attempt to connect
if (mqtt_client.connect(client_id, mqtt_username, mqtt_password)) {
mqtt_client.subscribe(heatpump_set_topic);
mqtt_client.subscribe(heatpump_debug_set_topic);
} else {
// Wait 5 seconds before retrying
delay(5000);
if (WiFi.status() !=WL_CONNECTED) //reconnect wifi
WIFIConnect();
void WIFIConnect() { //wifi reconnect
WiFi.disconnect();
//WiFi.mode(WIFI_STA); //set to not broadcast ssid
WiFi.begin(ssid, password);
wifiMillis = millis(); //start "timer"
while (WiFi.status() != WL_CONNECTED) { //sit here indefinitely trying to connect
// wait 500ms, flashing the blue LED to indicate WiFi connecting...
digitalWrite(blueLedPin, LOW);
delay(250);
delay(250);
if ((unsigned long)(millis() - wifiMillis) >= 20000) break;
//if (millis() > wifiMillis + 20000) break; //call reset
void loop() {
WIFIConnect();
} else {
if (!mqtt_client.connected()) {
mqttConnect();
hp.sync();
//if (millis() > (lastTempSend + SEND_ROOM_TEMP_INTERVAL_MS)) { // only send the temperature every 60s
if ((unsigned long)(millis() - lastTempSend) >= SEND_ROOM_TEMP_INTERVAL_MS) { //only send the temperature every 60s (default)
hpStatusChanged(hp.getStatus());
//if (millis() > (lastRemoteTemp + 300000)) { //reset to local temp sensor after 5 minutes of no remote temp
if ((unsigned long)(millis() - lastRemoteTemp) >= 300000) { //reset to local temp sensor after 5 minutes of no remote temp udpates
hp.setRemoteTemperature(0);
mqtt_client.loop();
#ifdef OTA
ArduinoOTA.handle();
#endif
