Hi… i have a Sonoff TH10 with a SI7021 sensor, that works great, and the switch in it works fine from openhab / habpanel, but I have some problems with getting temperature and humidity into habpanel, my sonoff outputs this:
09:40:46 MQT: tele/th01/SENSOR = {“Time”:“2018-06-10T09:40:46”,“SI7021”:{“Temperature”:23.8,“Humidity”:52.6},“TempUnit”:“C”}
and my times file looks like this:
Switch udestue1 "udestue1" <light> (Sonoff)
{ mqtt=">[broker:cmnd/th01/POWER:command:*:default],
<[broker:stat/th01/POWER:state:default]" }
Number th01_temp "TH01 Temperatur[%.2f °C]" <temperature> (Sonoff)
{mqtt="<[broker:tele/th01/SENSOR:state:JSONPATH($.SI7021.Temperature)]"}
Number th01_humi "TH01 Humidity[%d %%]" <humidity> (Sonoff)
{mqtt="<[broker:tele/th01/SENSOR:state:JSONPATH($.SI7021.Humidity)]"}
Switch works, so no problems there, but my temp and humidity sensor, only returns “NULL” to habpanel, I have searched and searched, but not find the right way yet, I have installed the JsonPath Transformation, but can’t figure out, if I have to do something with the transformation, or it only needs to be installed…? or if there is somethings else wrong…
