I have an ESP-8266EX with Tasmota and I am reading the values via MQTT. I get the following topic:
'{"Time":"2022-12-14T21:55:36","AM2301":{"Temperature":22.0,"Humidity":56.7,"DewPoint":13.0},"SDS0X1":{"PM2.5":4.6,"PM10":5.0},"TempUnit":"C"}'
With
transformationPattern="JSONPATH:$.SDS0X1.PM10
I get the correct value of PM10.
But reading PM2.5 does not work with
transformationPattern=JSONPATH:$.SDS0X1.PM2.5
because of the “.”
How to do it correctly? Thanks a lot!
JustinG
(JustinG)
December 14, 2022, 9:29pm
#2
JSONPATH should accept both .
and [ ]
forms. So in this case:
JSONPATH:$.SDS0X1[PM2.5]
should work.
when using
I get
Executing the JSONPATH-transformation failed: An error occurred while transforming JSON expression.
rlkoshak
(Rich Koshak)
December 15, 2022, 2:17pm
#4
is for arrays and I don’t think that’s what we have here. Shouldn’t it be something like the following?
$.SDS0X1.PM2\.5
@liveislife Note the escaped .
has meaning to JSONPATH and without escaping it I would expect it to fail.
JustinG
(JustinG)
December 15, 2022, 2:42pm
#5
As I understand it, the implementation of JOSNPATH used should accept the bracket notation in general instances too:
However, you may have to put the key in quotes inside the bracket, so perhaps:
JSONPATH:$.SDS0X1['PM2.5']
But, escaping the period should also work.
Finally
has worked.
Instead
JSONPATH:$.SDS0X1.PM2\.5
ended with
Configuration model 'mqtt.things' has errors, therefore ignoring it: [6,124]: mismatched character '.' expecting set null [6,149]: mismatched character '<EOF>' expecting '"'
Thank you for your efforts!
