Gday,
Is it possible to enable or adjust the MQTT binding keep-alive settings.
I have two broker connections setup, mosquitto & a mysensors gateway. The mosquitto broker (for owntracks) is working really well however every 2 minutes, almost exactly, the connection to the mysensors broker drops and then reconnects.
After a little reading, here, I noticed that it is the clients job to keep the connection to the broker alive. So was wondering if there is a setting somewhere I could experiment with.
Regards,
George
