Hi there,
I’m trying to configure a set of lightbulbs/stripleds with OH2 and Google Home.
The objects are Itead, SonOFF items, flashed with Espurna firmware.
My problem is that I can’t understand how to create the items for controlling colors, brightness etc.
I’m able to turn on/off the lights with my voice via the item config below:
I’ve tried creating another item for controlling brightness (for example) but it don’t work and, if I say Turn on test light Google Home’s answer Ok, powering on two lights and nothing happen.
Maybe I wasn’t clear in my initial post:
I’ve configured all the items in the way you have seen in my previous posts. I’ve created the sliders/buttons etc in HABPanel and, via GUI, they works perfectly:
The colors, brightness and on/off works without any problem.
My problem is that I want to do it by my voice, via Google Assistant/Google Home.
I’ve created every item with the [ “Lighting” ] tag but it don’t work.
I’ve created a group, assigned every item (of a bulb, for example) to this group and added the tag just to the group, and it don’t work.
I don’t know how I’ve to do for controlling bright and colours (by my voice) because powering on/off works.
