I have chosen to create a new Topic after having not found an answer to my question here.
I would like HABpanel to report something different to its default for an Item status. To explain, I have this as my Item:
Switch livRm_blind1 "RollerBlind 1 " <rollershutter> { mqtt="<[localbrokerrb:Blind1_esp/posn:state:default],>[localbrokerrb:Blind1/cmd:command:ON:DOWN],>[localbrokerrb:Blind1/cmd:command:OFF:UP]" }
which in HABpanel shows either ON or OFF as status.
My mqtt commands instruct a roller blind to go “UP” or “DOWN” and I would like HABpanel to show the status accordingly instead of OFF or ON. The transform file updown.map contains:
DOWN= ON
UP=OFF
1=DOWN
0=UP
With the Item being defined as type Switch do I need to define another Item that can just display the mqtt message i.e. “UP” or “DOWN” or is there another way? Maybe a dummy widget in HABpanel?
