When I restart OPENHAB2 with the following command
I get a couple of messages in openahab.log
2017-11-17 09:18:58.456 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection ''
2017-11-17 09:18:59.021 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection ‘broker’
Notice the BROKER at the end of the lines (Ive highlighted them). Is this normal or should my IP address or host name be in there ?
Thanks in advance
