All
Looking for some help here. When I upgraded/rebuilt my OpenHAB set up, Ive lost almost ALL of my MQTT setups. I have several Items which are set up as strings (my blinds, and a few lights which work like old school 3 way lights -LOW/MEDIUM/HIGH) and I cant get the new set up to work. My issue is apparently there is now a transformation required which really throws a monkey wrench in my works.
Heres my items. (both my blinds and lights use the same command/state structure).
String blindrecroom "Blinds [%s] " <blind> (Bsmt_Rec) {mqtt=">[mosquitto:recroom/blind/setting:command:Open:90],>[mosquitto:recroom/blind/setting:command:Close:5],>[mosquitto:recroom/blind/setting:command:Closeup:150],>[mosquitto:recroom/blind/setting:command:Half:45],<[mosquitto:recroom/blind/status:state:default]"}
String blindoffice "Blinds [%s] " <blind> (FF_Office) {mqtt=">[mosquitto:office/blind/setting:command:Open:90],>[mosquitto:office/blind/setting:command:Close:5],>[mosquitto:office/blind/setting:command:Closeup:150],>[mosquitto:office/blind/setting:command:Half:45],<[mosquitto:office/blind/status:state:default]"}
String blindfamilyrm "Blinds [%s] " <blind> (FF_Living) {mqtt=">[openhabmqtt:familyrm/blind/setting:command:Open:90],>[openhabmqtt:familyrm/blind/setting:command:Close:5],>[openhabmqtt:familyrm/blind/setting:command:Closeup:150],>[openhabmqtt:familyrm/blind/setting:command:Half:45],<[openhabmqtt:familyrm/blind/status:state:default]"}
And on the sitemap there are 3-4 buttons. I dont use the slider on these.
Im able to get my simple on/off switches and temperature/humidity sensors working with the ‘new’ configuration, but am stumped on the blinds.
How can I get these to work again?
Dave
