There is a nice tutorial here:
http://owntracks.org/booklet/guide/broker/#mqtt-broker
Also worth reading:
Also worth reading:
I did the things again, but still no luck.
I get error:connection refused inside putty. I tried my ip, localhost and 127.0.0.1.
I donĀ“t get a logfile. I removed the logfile some time ago and there will not be created a new one? No idea, how i can check where i have a wrong configuration? I even removed the mosqutiio.conf file and restarted the server, but nothing helps.
I get the following inside my shell:
root@debian:~# /etc/init.d/mosquitto status
ā mosquitto.service - LSB: mosquitto MQTT v3.1 message broker
Loaded: loaded (/etc/init.d/mosquitto)
Active: active (exited) since Mi 2017-05-03 14:27:48 CEST; 5s ago
Process: 3318 ExecStop=/etc/init.d/mosquitto stop (code=exited, status=0/SUCCESS)
Process: 3915 ExecStart=/etc/init.d/mosquitto start (code=exited, status=0/SUCCESS)
Mai 03 14:27:48 debian systemd[1]: Starting LSB: mosquitto MQTT v3.1 message broker...
Mai 03 14:27:48 debian mosquitto[3915]: Starting network daemon:: mosquitto.
Mai 03 14:27:48 debian systemd[1]: Started LSB: mosquitto MQTT v3.1 message broker.
So i think it is running?
But with this two commands:
netstat -an |grep 1883
netstat -an |grep 8883
I donĀ“t get any output.
Here is the mosquitto deirectory. Is this ok? The rights for conf and password file are 644.
And here is my mosquitto.conf:
# Place your local configuration in /etc/mosquitto/conf.d/
# A full description of the configuration file is at
# /usr/share/doc/mosquitto/examples/mosquitto.conf.example
pid_file /var/run/mosquitto.pid
persistence true
persistence_location /var/lib/mosquitto/
log_dest file /var/log/mosquitto/mosquitto.log
include_dir /etc/mosquitto/conf.d
listener 1883 # UnverschlĆ¼sselte Verbindung. Sofern auf der Firewall nicht durchgeschleust nur fĆ¼r's heimische Netzwerk
listener 8883 # VerschlĆ¼sselte Verbindung fĆ¼r Clients Ć¼ber Port 8883 (kann in der Firewall durchgereicht werden)
retry_interval 20
user mqttuser
password_file /etc/mosquitto/passwd
Now i removed all password/username things and it is working with port 1883. No authentication.
Next thing is to change to port 8883 and after that i want to use authentication with username/password.
So what do i have to do, if i want to listen at 1883 and 8883?
This is working only on 1883:
persistence true
retry_interval 20
log_type error
log_type warning
log_type notice
log_type information
connection_messages true
log_timestamp true
And the strange thing is:
This is not working on 1883 and 8883:
persistence true
listener 1883
listener 8883
retry_interval 20
log_type error
log_type warning
log_type notice
log_timestamp true
I only added only this two lines to my config, no more other changes. Owntracks stopped working on my phone, i didnĀ“t get a connection anymore (same config on phone).
If i only add port 1883 and listener 8883 and phone still the same like before, it should normaly still work with old settings and on standard port 1883?
Yes, it should workā¦
port 1883 is the default listener
Also check the conf.d subdir not to have any other configs there (not likely)
On the phone set 1883 and disable tls and auth for the beggining
I use OT clients with only auth (no tls)
I didnĀ“t change config on the phone. Only added the two lines into the conf-file. There is no second conf-file.
TLS and auth are off.
So i think i will stay at 1883 and use only auth.
Do you also use only 1883? Is it possible to use 8883 without tls or is this the same like 1883?
Another question: I started testing with my two phones. After that i changed the names in owntracks app on both phones. Now i still get the last locations of the old phone-names. There are now 4 friends in it. I already removed the mosquitto.db, but after it is build new, there are still 4 friends in it. Do you know where it is stored and why the 4 friends are still there?
I use only 1883
I think that you can use 8883 without tls in parallel to 1883ā¦ but why would you do this?
I will give you more info soonā¦(also how to clear old stuff from OT )
The latest version of ot client on android includes the option to clear a friend.
Driving atm and using discourse mobile client to post so itās not easy to find the info.
Thanks, i have found it. I removed the friends.
In the /etc/mosquitto/mosquitto.conf
you set the following:
port 1883
<networking options>
listener 8883
listener <other port>
If you donāt define any <networking options>
, then you wonāt enable TLS (or other networking stuff)
A working example with the default listener on 1883, an extra listener on 8883 with TLS enabled and an extra listener without TLS on 9883 with protocol websockets enabled would look like:
port 1883
listener 8883
certfile /etc/encryption/blah/blah/cert.pem
cafile /etc/encryption/blah/blah/chain.pem
keyfile /etc/encryption/blah/blah/privkey.pem
listener 9883
protocol websockets
Source: MQTT Mosquitto broker with SSL/TLS transport security ā Primal Cortex's Weblog
Before this option on the mobile client app (OT), you could do the following:
Send an empty (-n) MQTT message to the topic and this would clear the friend:
mosquitto_pub -t owntracks/owntracks/<old_device_name> -r -n -u <username> -P <password>
After you have your MQTT Broker configured, your OT mobile clients connected and reporting their location history, your openHAB2 items configured, etcā¦ check out also the awesome Owntracks Recorder web app
Thanks, i will have a look on it.
MQTTitude-binding is only for using waypoints/areas? So i can check if someone is at home, at work, ā¦
Which binding do i have to use when i want to get the location and the street name and so on? Maybe show it on google maps.
Only MQTT-Binding?
The MQTTitude binding is basically going to give you a Presence Detection Solution. It will turn on a switch item when the location of a friend falls within the pre-defined geo-fenced region. You can then use this event (switch was turned on) to trigger a rule and perform other events from OH2.
I donāt use it personally (I have another presence detection solution with the Unifi binding) but I think that the answer to your question is yes.
btw: OwnTracks is the new name of MQTTitude but the binding name was never updated to OwnTracks
Yes, only the MQTT Binding (note: not the street nameā¦ see json payload info below).
Since the OT mobile clients will directly publish their locations on MQTT topics, you could use only the MQTT binding to communicate to OH2 the required info (subscribe to the topic and pull the data from there).
Nowā¦ what to do with the data (the json payload published in the topic) and how to use it to display for example a google map or the street name where a friend is on your sitemapā¦ thatās another journey (but itās possible)
Here is an example json payload coming from OT Android mobile client app (v1.1.7):
"_type": "location"
"tid":"S6",
"acc":"12",
"batt":"59",
"conn":"m",
"doze":"false",
"lat": "47.056987",
"lon": "10.623918",
"tst": "1389104761"
