Hi all,
I have an Openhab installation (Version 2.5.3) that only uses the files approach. Nothing has been created via paperUI and no paperUI configurations files are in the according folder. So plain file based.
When I create multiple things within a MQTT bridge, only the bridge and the first thing appear on PaperUI and even the command “smartphone:things list” in the console does not show all the configured things.
log:tail throws no errors.
Whats wrong with the file?
Horst
Bridge mqtt:broker:andimqttbroker "MQTT Broker.SCR" [host="192.168.0.2", secure=false]
Thing topic Generic_MQTT_Thing "MQTT Testlab.SCR" @ "Arbeitszimmer"
Channels:
Type switch : lamp "Kitchen Lamp" [ stateTopic="lamp/enabled", commandTopic="lamp/enabled/set" ]
Type switch : fancylamp "Fancy Lamp" [ stateTopic="fancy/lamp/state", commandTopic="fancy/lamp/command", on="i-am-on", off="i-am-off" ]
Type string : alarmpanel "Alarm system" [ stateTopic="alarm/panel/state", commandTopic="alarm/panel/set", allowedStates="ARMED_HOME,ARMED_AWAY,UNARMED" ]
Type colorRGB : lampcolor "Kitchen Lamp color" [ stateTopic="lamp/color", commandTopic="lamp/color/set", rgb=true ]
Type dimmer : blind "Blind" [ stateTopic="blind/state", commandTopic="blind/set", min=0, max=5, step=1 ]
Type number : kesselabgas "KesselAbgas" [stateTopic="gas/abgas", commandTopic="gas/abgas/set"]
Thing topic Generic_MQTT_Thing "MQTT Occupancy Sensor SCR" @ "NodON PIR"
Channels:
Type switch : PIRNodOn "PIR Sensor scr" [ stateTopic="openhab/PIR", commandTopic="openhab/PIR", retained=false, postCommand=false ]
Thing topic Generic_MQTT_Thing "MicroPlugSwitch SCR" @ "MicroSmartPlug"
Channels:
Type switch : MicroSmartPlugSwitch "MicroSmart On/Off" [ stateTopic="openhab/SmartPlug", commandTopic="openhab/SmartPlug", retained=false, postCommand=false ]
