Use < for inbound. It’s a subscription to the topic where the payload is being delivered from the ESP.
When the ESP will publish (e.g. “OPEN”), the OH2 item will receive the message from MQTT and update the state of the bound item
Extra note (for later): Your item definitions have some errors in them (e.g. Switch4 first command). Your major problem is that the MQTT Binding is not connecting to the Broker. Let’s fix this first, then we deal with the item configs. You do have some good item configs so they should be sending messages.
