I use openhab 1.8.3 at my raspberry pi and try to use the mqtt binding, placed at the addon dir.
At the same raspberry a mosquitto mqtt broker is running.
I’ve tested this server a several time with different tools (mosquitto_pub, mosquitto_sub)
everything is working fine.
openhab.cfg
mqtt:broker.url=tcp://localhost:1883
mqtt:broker.retain=true
mqtt:broker.clientId=openhab
home.sitemap
String calHoliday “hello [%s]” (GRoom2) { mqtt="<[broker:openhab/cal_holiday:state:default]" }
home.items
Frame label=“MQTT” {
Text item=calHoliday label=“Cal holiday”
I’m running this command:
sudo mosquitto_pub -d -t openhab/cal_holiday -m “cool”
getting in the logs:
2016-05-30 08:33:43.391 [TRACE] [o.i.t.m.i.MqttBrokerConnection] - Received message on topic ‘openhab/cal_holiday’ : cool
But the web of my openhab server is still shows an empty string.
Any ideas?
