i’m having trouble to get mqtt working within openhab.
Today i downloaded and installed openhabian on a raspberry pi 2.
after installing i ssh into te pi to install through the config util mqtt.
mqtt is running, i checked it with mqtt-spy, from command line on the pi i can send a mqtt update.
this is displayd in mqtt-spy.
when i look at the log file of openhab, there is one error involving mqtt.
what is causing this problem and how to solve this.
2018-01-04 14:54:53.144 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection 'mqtt'
2018-01-04 14:54:53.381 [ERROR] [penhab.io.transport.mqtt.MqttService] - Error starting broker connection
java.lang.IllegalArgumentException: tcp://127.0.0.1:1883/
at org.eclipse.paho.client.mqttv3.MqttConnectOptions.validateURI(MqttConnectOptions.java:497) [208:org.openhab.io.transport.mqtt:1.11.0]
at org.eclipse.paho.client.mqttv3.MqttAsyncClient.<init>(MqttAsyncClient.java:291) [208:org.openhab.io.transport.mqtt:1.11.0]
at org.eclipse.paho.client.mqttv3.MqttAsyncClient.<init>(MqttAsyncClient.java:185) [208:org.openhab.io.transport.mqtt:1.11.0]
at org.eclipse.paho.client.mqttv3.MqttClient.<init>(MqttClient.java:226) [208:org.openhab.io.transport.mqtt:1.11.0]
at org.openhab.io.transport.mqtt.internal.MqttBrokerConnection.openConnection(MqttBrokerConnection.java:295) [208:org.openhab.io.transport.mqtt:1.11.0]
at org.openhab.io.transport.mqtt.internal.MqttBrokerConnection.start(MqttBrokerConnection.java:99) [208:org.openhab.io.transport.mqtt:1.11.0]
at org.openhab.io.transport.mqtt.MqttService.updated(MqttService.java:115) [208:org.openhab.io.transport.mqtt:1.11.0]
at org.apache.felix.cm.impl.helper.ManagedServiceTracker.updated(ManagedServiceTracker.java:189) [7:org.apache.felix.configadmin:1.8.16]
at org.apache.felix.cm.impl.helper.ManagedServiceTracker.updateService(ManagedServiceTracker.java:152) [7:org.apache.felix.configadmin:1.8.16]
at org.apache.felix.cm.impl.helper.ManagedServiceTracker.provideConfiguration(ManagedServiceTracker.java:85) [7:org.apache.felix.configadmin:1.8.16]
at org.apache.felix.cm.impl.ConfigurationManager$ManagedServiceUpdate.provide(ConfigurationManager.java:1479) [7:org.apache.felix.configadmin:1.8.16]
at org.apache.felix.cm.impl.ConfigurationManager$ManagedServiceUpdate.run(ConfigurationManager.java:1435) [7:org.apache.felix.configadmin:1.8.16]
at org.apache.felix.cm.impl.UpdateThread.run0(UpdateThread.java:141) [7:org.apache.felix.configadmin:1.8.16]
at org.apache.felix.cm.impl.UpdateThread.run(UpdateThread.java:109) [7:org.apache.felix.configadmin:1.8.16]
do i have to change MQTT in ajg ?
sorry for all this maybe stupid questions, it’s my first time with openhab an mqtt.
i’m in the transit of domoticz to openhab
# Name of the broker as it is defined in the openhab.cfg. If this property is not available, no event bus MQTT binding will be created.
#broker=ajg
# When available, all status updates which occur on the openHAB event bus are published to the provided topic. The message content will
# be the status. The variable ${item} will be replaced during publishing with the item name for which the state was received.
#statePublishTopic=/openHAB/OUT/${item}/state
# When available, all commands which occur on the openHAB event bus are published to the provided topic. The message content will be the
# command. The variable ${item} will be replaced during publishing with the item name for which the command was received.
#commandPublishTopic=/openHAB/OUT/${item}/command
# When available, all status updates received on this topic will be posted to the openHAB event bus. The message content is assumed to be
# a string representation of the status. The topic should include the variable ${item} to indicate which part of the topic contains the
# item name which can be used for posting the received value to the event bus.
#stateSubscribeTopic=/openHAB/in/${item}/state
# When available, all commands received on this topic will be posted to the openHAB event bus. The message content is assumed to be a
# string representation of the command. The topic should include the variable ${item} to indicate which part of the topic contains the
#commandSubscribeTopic=/openHAB/in/${item}/command
