Hi i having problems with outgoing mqtt transformation
(Status/Set needs "amp=6" to set 6 amps.) Type string : Udenfor_0sal_forhave_goecharger_amp "Ampere value for the PWM signaling" [stateTopic="go-eCharger/014181/status", commandTopic="go-eCharger/014181/cmd/req", transformationPattern="JSONPATH:$.amp"]
Example from my things file, i get a 6 as status, but i need to sent a amp=6 to change the settings
i have 15-20 things that need this type of transformation.
Make sure your Item and Channel are Number type, then use:
formatBeforePublish="amp=%d"
New things line looks like this
Type number : Udenfor_0sal_forhave_goecharger_amp "Ampere value for the PWM signaling" [stateTopic="go-eCharger/014181/status", transformationPattern="JSONPATH:$.amp", commandTopic="go-eCharger/014181/cmd/req", formatBeforePublish="amp=%d"]
