I have binary mqtt data going left and right. I need to PUBLISH a mqtt number (watchdog to check for communications ok)
Number watchdog “watchdog master [%.1f]” (MS_Misc) {mqtt=">[main:/home/watchdog:state:default:*]"}
does not work. Can someone supply me with a paste from their items that publishes a mqtt number? Sorry for being so stupid and lazy.
Number watchdog "watchdog master [%.1f]" (MS_Misc) {mqtt=">[main:/home/watchdog:state:*:default]"}
The * and default needed to be swapped. The above item means:
whenever the numeric state of the item (watchdog) is updated, regardless of what it is (*), publish a string representation of the number unmodified (default) to the broker (main) as defined in openhab.cfg, to the MQTT topic (/home/watchdog).
