Raspberry pi running V2.2
I have a value I want to send out to MQTT and be picked up by other deivces.
I cant work out how to make a generic ‘take the value and publish it’ set up
as the item currently stands
//Number Output_mqtt {mqtt=">[mybroker:home/outputs:command:0:0],>[mybroker:home/outputs:command:1:1],>[mybroker:home/outputs:command:2:2]"}
Number Output_mqtt {mqtt=">[mybroker:home/outputs:command:*:.*]"}
The commented out line on top does work, but only for values 0, 1 and 2 as it suggests.
I guess I could the value through a map and set a load of possible values, and more just in case,
but I wanted to just have one line that wouldnt care what the value is, just send it out.
Is there a reason why the wildcard approach doesnt work?
FYI, I found the item setup somewhere and gave it a go but now it publishes ‘.*’
I changed the item to
Number Output_mqtt {mqtt=">[mybroker:home/outputs:command:*:*]"}
and it only publishes ‘*’
so the first ‘*’ isnt actually a wild card maybe???
