I am running Openhab on a Raspberry Pi4 with Docker. Containers installed are in the same n network are:
- OpenHAB
- Node-Red
- Influx
- Grafana
- Mosquitto
- zigbee2mqtt
- zigbee2mqttGUI
I am trying to migrate from the Openhabian installation on a RPi3. I started now to get this error:
2019-11-24 23:34:06.182 [thome.event.ItemStateEvent] - Bathroom1_Fan updated to OFF
==> /openhab/userdata/logs/openhab.log <==
2019-11-24 23:34:07.396 [ERROR] [ansport.mqtt.internal.ClientCallback] - MQTT message received. MqttMessageSubscriber#processMessage() implementation failure
java.lang.StringIndexOutOfBoundsException: String index out of range: 10
at java.lang.String.substring(String.java:1963) ~[?:1.8.0_222]
at org.eclipse.smarthome.core.library.types.DateTimeType.<init>(DateTimeType.java:121) ~[?:?]
at org.eclipse.smarthome.core.library.types.DecimalType.as(DecimalType.java:173) ~[?:?]
at org.eclipse.smarthome.core.internal.items.ItemStateConverterImpl.convertToAcceptedState(ItemStateConverterImpl.java:64) ~[?:?]
at org.eclipse.smarthome.core.thing.internal.profiles.ProfileCallbackImpl.sendUpdate(ProfileCallbackImpl.java:134) ~[?:?]
at org.eclipse.smarthome.core.thing.internal.profiles.SystemDefaultProfile.onStateUpdateFromHandler(SystemDefaultProfile.java:53) ~[?:?]
at org.eclipse.smarthome.core.thing.internal.CommunicationManager.lambda$9(CommunicationManager.java:467) ~[?:?]
at org.eclipse.smarthome.core.thing.internal.CommunicationManager.lambda$11(CommunicationManager.java:487) ~[?:?]
at java.lang.Iterable.forEach(Iterable.java:75) ~[?:1.8.0_222]
at org.eclipse.smarthome.core.thing.internal.CommunicationManager.handleCallFromHandler(CommunicationManager.java:483) ~[?:?]
at org.eclipse.smarthome.core.thing.internal.CommunicationManager.stateUpdated(CommunicationManager.java:465) ~[?:?]
at org.eclipse.smarthome.core.thing.internal.ThingManagerImpl$1.stateUpdated(ThingManagerImpl.java:168) ~[?:?]
at org.eclipse.smarthome.core.thing.binding.BaseThingHandler.updateState(BaseThingHandler.java:257) ~[?:?]
at org.openhab.binding.mqtt.generic.AbstractMQTTThingHandler.updateChannelState(AbstractMQTTThingHandler.java:234) ~[?:?]
at org.openhab.binding.mqtt.generic.ChannelState.processMessage(ChannelState.java:204) ~[?:?]
at org.eclipse.smarthome.io.transport.mqtt.internal.ClientCallback.lambda$3(ClientCallback.java:96) ~[?:?]
at java.util.ArrayList.forEach(ArrayList.java:1257) ~[?:1.8.0_222]
at org.eclipse.smarthome.io.transport.mqtt.internal.ClientCallback.messageArrived(ClientCallback.java:96) ~[?:?]
at org.eclipse.smarthome.io.transport.mqtt.internal.ClientCallback.messageArrived(ClientCallback.java:71) ~[?:?]
at com.hivemq.client.internal.mqtt.mqtt3.Mqtt3AsyncClientView.lambda$callbackView$1(Mqtt3AsyncClientView.java:73) ~[bundleFile:?]
at com.hivemq.client.internal.mqtt.MqttAsyncClient$CallbackSubscriber.onNext(MqttAsyncClient.java:227) [bundleFile:?]
at com.hivemq.client.internal.mqtt.MqttAsyncClient$CallbackSubscriber.onNext(MqttAsyncClient.java:212) [bundleFile:?]
at com.hivemq.client.rx.FlowableWithSingle$SingleFutureSubscriber.onNext(FlowableWithSingle.java:377) [bundleFile:?]
at com.hivemq.client.internal.rx.operators.FlowableWithSingleCombine$SplitSubscriber$Default.tryOnNextActual(FlowableWithSingleCombine.java:206) [bundleFile:?]
at com.hivemq.client.internal.rx.operators.FlowableWithSingleCombine$SplitSubscriber.tryOnNext(FlowableWithSingleCombine.java:171) [bundleFile:?]
at io.reactivex.internal.operators.flowable.FlowableObserveOn$ObserveOnConditionalSubscriber.runAsync(FlowableObserveOn.java:649) [bundleFile:?]
at io.reactivex.internal.operators.flowable.FlowableObserveOn$BaseObserveOnSubscriber.run(FlowableObserveOn.java:176) [bundleFile:?]
at io.reactivex.internal.schedulers.ScheduledRunnable.run(ScheduledRunnable.java:66) [bundleFile:?]
at io.reactivex.internal.schedulers.ScheduledRunnable.call(ScheduledRunnable.java:57) [bundleFile:?]
at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:1.8.0_222]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) [?:1.8.0_222]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) [?:1.8.0_222]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_222]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_222]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_222]
==> /openhab/userdata/logs/events.log <==
The messages do not contain information so that I understand what the real problem is. How can I narrow down what the problem is? It seems to bet triggered in the proximity of some items but I have not yet found which of them do not work.
Any help in pointing me into a direction for investigation is welcome.
