I have my OpenHAB set up mostly using ESP8266 nodes dotted around.
Recently I have added a Sonoff AC relay module in the garden shed which turns the garden up lighters ON and OFF.
I am not sure if this is a little too far away from my home router, but sometimes it doesnt listen to commands (especially OFF commands, after being turned on for a while), I will have to work out if this is a issue with my WiFi signal or another issue.
My question is, when OpenHAB sends a OFF command to Topic /Garden/relay/1/com/, rather than OpenHAB just assuming that the message was picked up by the Sonoff, OpenHAB waits till it receives a confirmation command of OFF to topic /Garden/relay/1/state/ before it turns the GUI switch off.
Make sense? Is it possible? I have googled it but not found any info.
You will probably want to use a Proxy Item and separate Items for commanding and receiving the update. I’ll call them Proxy, Out, and In.
Proxy: you use this in your Rules and on your sitemap. As far as anything else is concerned, Proxy represents this Device
Out: bound to /Garden/relay/1/com/ (NOTE: the initial ‘/’ is considered deprecated and brokers like Mosquitto may stop supporting topic names that start with ‘/’ that at some point). This Item is responsible for sending the commands to the device
In: bound to /Garden/relay/1/state/. This Item is responsible for receiving the new state from the device
Now you need some rules to make these three Items work together. You need:
A rule that triggers when Proxy receives a command that forwards the command to Out and sets a Timer. The Timer sets the Proxy back to the previous state if it goes off.
A rule that triggers when In receives a command that cancels the Timer and sets the Proxy to the current state of the device.
val Timer proxyTimer = null
rule "Proxy received command"
Item Proxy received command
if(proxyTimer == NULL || proxyTimer.hasTerminated) {
proxyTimer = createTimer(now.plusSeconds(5), [|
Proxy.postUpdate(if(receivedCommand == ON) OFF else ON)
else {
proxyTimer.reschedule(now.plusSeconds(5)
Out.sendCommand(receivedCommand)
rule "In received update"
Item In received update
if(proxyTimer != null) {
proxyTimer.cancel
proxyTimer = null
Proxy.postUpdate(In.state)
Behavior is on your sitemap the Switch will bounce back to its previous state if the device didn’t receive the command and change.
An alternative that doesn’t use a Timer would be:
A rule that triggers on Proxy received command, resets Proxy back to its old state and forwards the command to Out
A rule that triggers when In receives a command that sets Proxy to the current state of the device.
autoupdate=“false” will, if both the incoming and outgoing MQTT binding configs are on the same Item, cause the incoming messages to only postUpdate the Item instead of sendCommand (which would result in an infinite loop). But it would not solve your problem.
import org.openhab.model.script.actions.Timer
var Timer timer
var int counter = 0
rule "Turn off lights if failed"
Item Garden_Lights received command OFF
Thread::sleep(2000)
if(Garden_Lights.state==ON) {
logInfo("GardenLight", "Commanded OFF, but still ON. Retry OFF in 10 Secs")
timer = createTimer(now.plusSeconds(10)) [|
counter = counter + 1
logInfo("GardenLight", "Attempting Turn OFF Garden_Lights, attempt " + counter)
sendCommand(Garden_Lights, OFF)
if (counter==20){
logInfo("GardenLight", "Failed to turn off after " + counter " attempts")
timer.cancel
timer = null
counter = 0
} else {
if(timer!=null) {
timer.cancel
logInfo("GardenLight", "Lights have been successfully turned off, Timer Cancel")
sendNotification("Email@gmail.com", "Garden Lights OFF " + counter)
timer = null
counter = 0
This does seem to work when testing on a spare node on the workbench, although it doesnt fix my issue with the garden light, there must be something fishing about the arduino code running on it which i will have to debug.
