At first on the android OpenHab app, it just works as it should on=displays on icon, off=displays off icon
(Even if I turn it off or on via another PC Basic UI).
On my chrome desktop web-browser however, the state icon does not change even when turning it on or off from the browser. I have to hit F5ā¦
What causes this?
Other switches like Intertechno switches do not suffer from thisā¦
Log seems normal too:
2018-01-20 21:28:57.734 [ome.event.ItemCommandEvent] - Item āGF_Dining_Lightsā received command ON
2018-01-20 21:28:57.752 [vent.ItemStateChangedEvent] - GF_Dining_Lights changed from OFF to ON
2018-01-20 21:29:02.704 [ome.event.ItemCommandEvent] - Item 'GF_Dining_Lights' received command OFF
2018-01-20 21:29:03.168 [vent.ItemStateChangedEvent] - GF_Dining_Lights changed from ON to OFF
it works - but you could run into some headaches, especially if youād like to subscribe with wildcards and stuff
one-to-one communication is absolute fine, though.
Yesterday I flashed 2 Sonoff clones with ESP_EASY.
I called them ESP_Easy3 and ESP_Easy4ā¦
I now have this weird phenomena that each time I suscribe to ESP_Easy3/# and/or ESP_Easy4/# I find a bunch of /ESP_Easy3/gpio/4,1 /ESP_Easy3/gpio/15,1 and /ESP_Easy4/gpio/4,1 /ESP_Easy4/gpio/15,1
What is really driving me nuts is the fact that I only used ESP_Easy4 at my desk to check that flash worked.
So I am not sure what is actually sending out this MQTT message.
Not sure if some persist or bug (my mistake somewhere) in Openhab, or a broker issue, orā¦
I checked the .items files and .sitemap on openhab and cannot find anything even containing Easy4ā¦
hmmm. I donāt know, how ESP_Easy works, soā¦
I donāt know a way on how to see the client-id while subscribing, that would be the first way.
Next would be to disconnect the devices one by one and find out, whoās the evil one!
The way to see client-id seems to be broker-dependent� perhaps someone else can help here.
Is actually turned out to be that I had messages set as retained and Iām not sure what caused that and I could not delete them. I finally simply clearing out the mosquito database fixed it in a crude way. I also made sure message retaining is off from openhab.
