Hi there,
Since I migratet to OH3, I’m also using the newest mqtt binding. I got everything running, only a little pain remains…on the UI’s, the state is shown additionally as “ON” or “OFF”, which is useless for switches due their state is already shown with their depiction. I created my things as follows:
But I’m woundering, ONLY the mqtt items show their state “ON/OFF” in the sitemap…and I don’t know how to eliminate them…
And: it’s a new issue, did not had it with mqtt 1.xx…
We should rearrange your question. By default, where you haven’t given any [state presentation] instruction to an xxx.items defined Item, sitemap based widgets will show the string version of the Item’s state in the UI.
So the MQTT Items are working as expected.
So the question is … what channels/bindings are your other Items linked to, that affects their default presentation?
