heres some logs, this is from mosquitto -v, 530ca1b222e145729021a44b4ce0f40b is the MQTT.FX client
sudo mosquitto -v
1630770473: mosquitto version 1.5.7 starting
1630770473: Using default config.
1630770473: Opening ipv4 listen socket on port 1883.
1630770473: Opening ipv6 listen socket on port 1883.
1630770473: New connection from 127.0.0.1 on port 1883.
1630770473: New client connected from 127.0.0.1 as mqttjs_eafff369 (c1, k60, u’Openmin’).
1630770473: Will message specified (7 bytes) (r1, q0).
1630770473: zigbee2mqtt/bridge/state
1630770473: Sending CONNACK to mqttjs_eafff369 (0, 0)
1630770473: Received SUBSCRIBE from mqttjs_eafff369
1630770473: zigbee2mqtt/# (QoS 0)
1630770473: mqttjs_eafff369 0 zigbee2mqtt/#
1630770473: Sending SUBACK to mqttjs_eafff369
1630770473: Received PUBLISH from mqttjs_eafff369 (d0, q0, r0, m0, ‘zigbee2mqtt/bridge/logging’, … (53 bytes))
1630770473: Sending PUBLISH to mqttjs_eafff369 (d0, q0, r0, m0, ‘zigbee2mqtt/bridge/logging’, … (53 bytes))
1630770473: Received PUBLISH from mqttjs_eafff369 (d0, q0, r0, m0, ‘zigbee2mqtt/bridge/logging’, … (93 bytes))
1630770473: Sending PUBLISH to mqttjs_eafff369 (d0, q0, r0, m0, ‘zigbee2mqtt/bridge/logging’, … (93 bytes))
1630770473: Received PUBLISH from mqttjs_eafff369 (d0, q0, r1, m0, ‘zigbee2mqtt/bridge/state’, … (6 bytes))
1630770473: Sending PUBLISH to mqttjs_eafff369 (d0, q0, r0, m0, ‘zigbee2mqtt/bridge/state’, … (6 bytes))
1630770498: New connection from 192.168.8.222 on port 1883.
1630770498: New client connected from 192.168.8.222 as 530ca1b222e145729021a44b4ce0f40b (c1, k60, u’Openmin’).
1630770498: No will message specified.
1630770498: Sending CONNACK to 530ca1b222e145729021a44b4ce0f40b (0, 0)
1630770504: Received SUBSCRIBE from 530ca1b222e145729021a44b4ce0f40b
1630770504: zigbee2mqtt/boiler (QoS 0)
1630770504: 530ca1b222e145729021a44b4ce0f40b 0 zigbee2mqtt/boiler
1630770504: Sending SUBACK to 530ca1b222e145729021a44b4ce0f40b
1630770512: Received PUBLISH from mqttjs_eafff369 (d0, q0, r0, m0, ‘zigbee2mqtt/bridge/logging’, … (177 bytes))
1630770512: Sending PUBLISH to mqttjs_eafff369 (d0, q0, r0, m0, ‘zigbee2mqtt/bridge/logging’, … (177 bytes))
1630770512: Received PUBLISH from mqttjs_eafff369 (d0, q0, r0, m0, ‘zigbee2mqtt/bridge/logging’, … (291 bytes))
1630770512: Sending PUBLISH to mqttjs_eafff369 (d0, q0, r0, m0, ‘zigbee2mqtt/bridge/logging’, … (291 bytes))
1630770512: Received PUBLISH from mqttjs_eafff369 (d0, q1, r1, m45997, ‘zigbee2mqtt/boiler’, … (192 bytes))
1630770512: Sending PUBACK to mqttjs_eafff369 (Mid: 45997)
1630770512: Sending PUBLISH to mqttjs_eafff369 (d0, q0, r0, m0, ‘zigbee2mqtt/boiler’, … (192 bytes))
1630770512: Sending PUBLISH to 530ca1b222e145729021a44b4ce0f40b (d0, q0, r0, m0, ‘zigbee2mqtt/boiler’, … (192 bytes))
1630770530: Received PUBLISH from mqttjs_eafff369 (d0, q0, r0, m0, ‘zigbee2mqtt/bridge/logging’, … (83 bytes))
1630770530: Sending PUBLISH to mqttjs_eafff369 (d0, q0, r0, m0, ‘zigbee2mqtt/bridge/logging’, … (83 bytes))
1630770564: Received PINGREQ from 530ca1b222e145729021a44b4ce0f40b
1630770564: Sending PINGRESP to 530ca1b222e145729021a44b4ce0f40b
1630770581: New connection from 127.0.0.1 on port 1883.
1630770581: New client connected from 127.0.0.1 as b8fb763b-f51a-4f59-8638-43f926739037 (c1, k60, u’Openmin’).
1630770581: No will message specified.
1630770581: Sending CONNACK to b8fb763b-f51a-4f59-8638-43f926739037 (0, 0)
1630770582: Received SUBSCRIBE from b8fb763b-f51a-4f59-8638-43f926739037
1630770582: milight/states/# (QoS 1)
1630770582: b8fb763b-f51a-4f59-8638-43f926739037 1 milight/states/#
1630770582: Sending SUBACK to b8fb763b-f51a-4f59-8638-43f926739037
1630770583: Received SUBSCRIBE from b8fb763b-f51a-4f59-8638-43f926739037
1630770583: homeassistant/# (QoS 1)
1630770583: b8fb763b-f51a-4f59-8638-43f926739037 1 homeassistant/#
1630770583: Sending SUBACK to b8fb763b-f51a-4f59-8638-43f926739037
1630770583: +/+/$homie (QoS 1)
1630770583: b8fb763b-f51a-4f59-8638-43f926739037 1 +/+/$homie
1630770583: zigbee2mqtt/boiler (QoS 1)
1630770583: b8fb763b-f51a-4f59-8638-43f926739037 1 zigbee2mqtt/boiler
1630770583: Sending PUBLISH to b8fb763b-f51a-4f59-8638-43f926739037 (d0, q1, r1, m1, ‘zigbee2mqtt/boiler’, … (192 bytes))
1630770583: Received PUBACK from b8fb763b-f51a-4f59-8638-43f926739037 (Mid: 1)
1630770583: zigbee2mqtt/plug (QoS 1)
1630770583: b8fb763b-f51a-4f59-8638-43f926739037 1 zigbee2mqtt/plug
1630770590: Received PINGREQ from mqttjs_eafff369
1630770590: Sending PINGRESP to mqttjs_eafff369
1630770624: Received PINGREQ from 530ca1b222e145729021a44b4ce0f40b
1630770624: Sending PINGRESP to 530ca1b222e145729021a44b4ce0f40b
1630770632: Received PUBLISH from mqttjs_eafff369 (d0, q0, r0, m0, ‘zigbee2mqtt/bridge/logging’, … (177 bytes))
1630770632: Sending PUBLISH to mqttjs_eafff369 (d0, q0, r0, m0, ‘zigbee2mqtt/bridge/logging’, … (177 bytes))
1630770632: Received PUBLISH from mqttjs_eafff369 (d0, q0, r0, m0, ‘zigbee2mqtt/bridge/logging’, … (291 bytes))
1630770632: Sending PUBLISH to mqttjs_eafff369 (d0, q0, r0, m0, ‘zigbee2mqtt/bridge/logging’, … (291 bytes))
1630770632: Received PUBLISH from mqttjs_eafff369 (d0, q1, r1, m46001, ‘zigbee2mqtt/boiler’, … (192 bytes))
1630770632: Sending PUBACK to mqttjs_eafff369 (Mid: 46001)
1630770632: Sending PUBLISH to mqttjs_eafff369 (d0, q0, r0, m0, ‘zigbee2mqtt/boiler’, … (192 bytes))
1630770632: Sending PUBLISH to 530ca1b222e145729021a44b4ce0f40b (d0, q0, r0, m0, ‘zigbee2mqtt/boiler’, … (192 bytes))
1630770632: Sending PUBLISH to b8fb763b-f51a-4f59-8638-43f926739037 (d0, q1, r0, m2, ‘zigbee2mqtt/boiler’, … (192 bytes))
1630770632: Received PUBACK from b8fb763b-f51a-4f59-8638-43f926739037 (Mid: 2)
1630770684: Received PINGREQ from 530ca1b222e145729021a44b4ce0f40b
1630770684: Sending PINGRESP to 530ca1b222e145729021a44b4ce0f40b
1630770692: Received PINGREQ from b8fb763b-f51a-4f59-8638-43f926739037
1630770692: Sending PINGRESP to b8fb763b-f51a-4f59-8638-43f926739037
1630770692: Received PINGREQ from mqttjs_eafff369
1630770692: Sending PINGRESP to mqttjs_eafff369
1630770744: Received PINGREQ from 530ca1b222e145729021a44b4ce0f40b
1630770744: Sending PINGRESP to 530ca1b222e145729021a44b4ce0f40b
1630770752: Received PINGREQ from b8fb763b-f51a-4f59-8638-43f926739037
1630770752: Sending PINGRESP to b8fb763b-f51a-4f59-8638-43f926739037
1630770752: Received PINGREQ from mqttjs_eafff369
1630770752: Sending PINGRESP to mqttjs_eafff369
1630770753: Received PUBLISH from mqttjs_eafff369 (d0, q0, r0, m0, ‘zigbee2mqtt/bridge/logging’, … (177 bytes))
1630770753: Sending PUBLISH to mqttjs_eafff369 (d0, q0, r0, m0, ‘zigbee2mqtt/bridge/logging’, … (177 bytes))
1630770753: Received PUBLISH from mqttjs_eafff369 (d0, q0, r0, m0, ‘zigbee2mqtt/bridge/logging’, … (291 bytes))
1630770753: Sending PUBLISH to mqttjs_eafff369 (d0, q0, r0, m0, ‘zigbee2mqtt/bridge/logging’, … (291 bytes))
1630770753: Received PUBLISH from mqttjs_eafff369 (d0, q1, r1, m46004, ‘zigbee2mqtt/boiler’, … (192 bytes))
1630770753: Sending PUBACK to mqttjs_eafff369 (Mid: 46004)
1630770753: Sending PUBLISH to mqttjs_eafff369 (d0, q0, r0, m0, ‘zigbee2mqtt/boiler’, … (192 bytes))
1630770753: Sending PUBLISH to 530ca1b222e145729021a44b4ce0f40b (d0, q0, r0, m0, ‘zigbee2mqtt/boiler’, … (192 bytes))
1630770753: Sending PUBLISH to b8fb763b-f51a-4f59-8638-43f926739037 (d0, q1, r0, m3, ‘zigbee2mqtt/boiler’, … (192 bytes))
1630770753: Received PUBACK from b8fb763b-f51a-4f59-8638-43f926739037 (Mid: 3)
