I am running openHab 3.1 and am trying to intigrate my Fujitsu AC with a esp8266 running Tasmota. The temperature value and mode settings are getting read and put into the item’s string value. The power status is not getting its value. Can anyone see what i am missing?
This is my thing setup:
Thing topic AC_Keuken "Tasmota IRSend AC Keuken" @ "keuken" {
Channels:
Type string : reachable "Reachable" [ stateTopic="tele/tasmota_21659E/LWT" ]
Type switch : power "Power" [ stateTopic="stat/tasmota_21659E/RESULT", transformationPattern="JSONPATH:$.IrReceived.IRHVAC.Power"]
Type number : setpoint "temp ingesteld" [ stateTopic="tele/tasmota_21659E/RESULT", transformationPattern="JSONPATH:$.IrReceived.IRHVAC.Temp"]
Type string : mode "mode" [ stateTopic="tele/tasmota_21659E/RESULT", transformationPattern="JSONPATH:$.IrReceived.IRHVAC.Mode"]
Type string : fanspeed "Ventilator" [ stateTopic="tele/tasmota_21659E/RESULT", transformationPattern="JSONPATH:$.IrReceived.IRHVAC.FanSpeed"]
Type string : swingv "SwingV" [ stateTopic="tele/tasmota_21659E/RESULT", transformationPattern="JSONPATH:$.IrReceived.IRHVAC.SwingV"]
Type string : swingh "SwingH" [ stateTopic="tele/tasmota_21659E/RESULT", transformationPattern="JSONPATH:$.IrReceived.IRHVAC.SwingH"]
Type string : quiet "Stil" [ stateTopic="tele/tasmota_21659E/RESULT", transformationPattern="JSONPATH:$.IrReceived.IRHVAC.Quiet"]
Type string : econo "Economisch" [ stateTopic="tele/tasmota_21659E/RESULT", transformationPattern="JSONPATH:$.IrReceived.IRHVAC.Econo"]
My Items:
String Tasmota_ACIRSend "Tasmota IRSend LWT" { channel="mqtt:topic:mosquitto:AC_Keuken:reachable"}
Switch ACKeuken_Power "Airco draait" <climate> { channel="mqtt:topic:mosquitto:AC_Keuken:power" }
Number ACKeuken_Setpoint "Temp Ingesteld" <climate> { channel="mqtt:topic:mosquitto:AC_Keuken:setpoint"}
String ACKeuken_Mode "Modus" <climate> { channel="mqtt:topic:mosquitto:AC_Keuken:mode" }
String ACKeuken_Fanspeed "Ventilator" <climate> { channel="mqtt:topic:mosquitto:AC_Keuken:fanspeed" }
String ACKeuken_SwingV "SwingV" <climate> { channel="mqtt:topic:mosquitto:AC_Keuken:swingv" }
String ACKeuken_SwingH "SwingH" <climate> { channel="mqtt:topic:mosquitto:AC_Keuken:swingh" }
String ACKeuken_Quiet "Stil" <climate> { channel="mqtt:topic:mosquitto:AC_Keuken:quiet" }
String ACKeuken_Econo "Economisch" <climate> { channel="mqtt:topic:mosquitto:AC_Keuken:econo" }
This is received by the mqtt server:
{"IrReceived":{"Protocol":"FUJITSU_AC","Bits":128,"Data":"0x1463001010FE0930510130000000202E","Repeat":0,"IRHVAC":{"Vendor":"FUJITSU_AC","Model":1,"Mode":"Cool","Power":"On","Celsius":"On","Temp":21,"FanSpeed":"Auto","SwingV":"Auto","SwingH":"Auto","Quiet":"Off","Turbo":"Off","Econo":"Off","Light":"Off","Filter":"Off","Clean":"Off","Beep":"Off","Sleep":-1}}}
This is in my logs:
16:02:07.691 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ACKeuken_SwingH' changed from Off to Auto
16:02:07.692 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ACKeuken_Mode' changed from Auto to Cool
16:02:07.693 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ACKeuken_Setpoint' changed from 16 to 21
16:02:07.693 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ACKeuken_SwingV' changed from Off to Auto
For the moment just trying to get the AC’s state in to OH next step will be sending a change from OH to my AC
