I cannot see anything published in MQTTfx under # from this switch.
When using MQTTfx to publish to my pine64 as mqtt broker it works fine and my lights turn on/off.
I’ve tried reinstalling, checking my config files for multiple entries of the mqtt.cfg changes, trying multiple things in the .items file aswell(such as changing inbound/outbound).
Anyone have a solution to why there is no published MQTT from this setup?
I have a similar problem with my mqtt binding. I wanted to create a new topic, but I think this one is the same. I had it running and had every config file backuped. Yesterday I installed openhabian and with it’s config mosquitto. Then I copied the backup to the new system. Now it’s not working.
The Broker is working. The energyplug sends updates to my PC-client.
I tried changing the name like it was suggested, but it did not work.
Could someone look at my code? I’m probably missing the obvious…
Switch Steckdose "Die Steckdose ist " {mqtt="<[openbroker:stat/sonoff/POWER:state:default],>[openbroker:cmnd/sonoff/power:command:*:default]"}
default.sitemap
Switch item=Steckdose
This is what the logfile gives me when I press the switch
2017-03-02 20:55:11.640 [ItemCommandEvent ] - Item 'Steckdose' received command OFF
2017-03-02 20:55:11.649 [ItemStateChangedEvent ] - Steckdose changed from ON to OFF
2017-03-02 20:55:12.617 [ItemCommandEvent ] - Item 'Steckdose' received command ON
2017-03-02 20:55:12.626 [ItemStateChangedEvent ] - Steckdose changed from OFF to ON
I am still having issues with my OpenHAB MQTT Client publishing any messages at all.
I have tried as you suggested and i tried reinstalling all the .CFG files as well.
I copied your suggested items and names directly with no luck.
No published MQTT messages logged in my MQTT.fx logs when attempting to use the switch. I can still publish messages from my MQTT Dash phone app and MQTT.fx computer program and communicate with the broker.
Any information I can give which would help find the problem?
