This driving me crazy! It is working now But i have NO IDEA WHY!?
I run on a Raspberry 3 openhab 2.
i send via mqtt data to the same raspberry: the output of my topic subscribe are:
mosquitto_sub -v -h localhost -p 1883 -t '#'
terra/weather/Temperature 21.77
terra/weather/Humidity 40.26
terra/weather/Pressure 1000.51
Now i add the mqtt addon to my openhab2 services mqtt.cfg with:
# URL to the MQTT broker, e.g. tcp://localhost:1883 or ssl://localhost:8883
mqttbroker.url=tcp://localhost:1883
In my Item i add the line:
`Number GF_Terrace_Temperature "Temperatur [%.2f °C] " <temperature> (GF_Terrace, gTemperature) {mqtt="<[mqttbroker:terra/weather/Temperature:state:default]"}`
I get only this error openhab log:
2018-03-31 10:49:43.860 [ERROR] [org.apache.felix.configadmin ] - Cannot use configuration org.openhab.mqtt for [org.openhab.io.transport.mqtt.MqttService, org.osgi.service.cm.ManagedService, id=307, bundle=208/mvn:org.openhab.io/org.openhab.io.transport.mqtt/1.11.0]: No visibility to configuration bound to mvn:org.openhab.action/org.openhab.action.mqtt/1.11.0
on my Basic UI i only get -°C
no temperature is showing
I check all setting countless times: (
Anybody can help?
