I’m kind of stuck here. I set up a brand new OpenHAB2 environment and it works just fine so far. Now I wanted to add some sugar to it, namely have a temperature graph displayed somewhere. So I have InfluxDB set up, which also works fine for my Hue lamps. My persist configuration tells openHab to persist any change and all values every minute:
Temperature values are received via MQTT (I can display them in a HabPanel just fine, so they really reach openHab), but those values are not persisted and I have no clue why.
I kicked it several times quite hard … And it didn’t change anything. Meanwhile I started to develop a little tool subscribing to the MQTT broker and write the values to a MySQL database. This morning I checked both the MySQL database and the InfluxDB and BOTH are filled with data.
So unfortunately I have no clue what the problem was and what solved it, but now it works. Quite unsatisfying … So whoever has the same problem: Sorry, I don’t know what I did to make it work
If you have a problem with a “new” binding, appending to a two year old thread probably won’t help.
“same issue” = “All data are persisted but not what come from MQTT” ?
Don’t be shy about creating a new thread and being specific about your issue.
What are your Items - strings, numbers? What does your influx.persist look like? 8 or 9? Any messages in openhab.log at startup?
