Hallo Leute,
ich bin am verzweifeln… Ich bekomme MQTT nicht stabil ans laufen…
Ich verwende OpenHab 1.8.x
Nach 10 Sekunden verliert OPENHAB immer die Connection und kann nichts senden. Danach verbindet er wieder und sendet und nach 10 Sekunden ist die Connection wieder weg…
Was kann das sein ?
14:58:13.783 [INFO ] [o.i.t.m.i.MqttBrokerConnection:114 ] - Starting MQTT broker connection 'openhab_srv’
14:58:23.815 [ERROR] [o.i.t.m.i.MqttBrokerConnection:536 ] - MQTT connection to broker was lost
org.eclipse.paho.client.mqttv3.MqttException: Verbindung wurde getrennt
at org.eclipse.paho.client.mqttv3.internal.CommsReceiver.run(CommsReceiver.java:138) [mqtt-client-0.4.0.jar:na]
at java.lang.Thread.run(Thread.java:745) [na:1.8.0_101]
Caused by: java.io.EOFException: null
at java.io.DataInputStream.readByte(DataInputStream.java:267) ~[na:1.8.0_101]
at org.eclipse.paho.client.mqttv3.internal.wire.MqttInputStream.readMqttWireMessage(MqttInputStream.java:56) ~[na:na]
at org.eclipse.paho.client.mqttv3.internal.CommsReceiver.run(CommsReceiver.java:100) [mqtt-client-0.4.0.jar:na]
… 1 common frames omitted
14:58:23.818 [ERROR] [o.i.t.m.i.MqttBrokerConnection:540 ] - MQTT connection to ‘openhab_srv’ was lost: Verbindung wurde getrennt : ReasonCode 32109 : Cause : null
14:58:23.820 [INFO ] [o.i.t.m.i.MqttBrokerConnection:547 ] - Starting connection helper to periodically try restore connection to broker 'openhab_srv’
14:58:33.820 [INFO ] [o.i.t.m.i.MqttBrokerConnection:114 ] - Starting MQTT broker connection 'openhab_srv’
14:58:43.840 [ERROR] [o.i.t.m.i.MqttBrokerConnection:536 ] - MQTT connection to broker was lost
14:58:43.842 [ERROR] [o.i.t.m.i.MqttBrokerConnection:540 ] - MQTT connection to ‘openhab_srv’ was lost: Verbindung wurde getrennt : ReasonCode 32109 : Cause : null
14:58:43.842 [INFO ] [o.i.t.m.i.MqttBrokerConnection:547 ] - Starting connection helper to periodically try restore connection to broker 'openhab_srv’
14:58:53.844 [INFO ] [o.i.t.m.i.MqttBrokerConnection:114 ] - Starting MQTT broker connection 'openhab_srv’
14:59:03.860 [ERROR] [o.i.t.m.i.MqttBrokerConnection:536 ] - MQTT connection to broker was lost
14:59:03.862 [ERROR] [o.i.t.m.i.MqttBrokerConnection:540 ] - MQTT connection to ‘openhab_srv’ was lost: Verbindung wurde getrennt : ReasonCode 32109 : Cause : null
Die MQTT Sektion
URL to the MQTT broker, e.g. tcp://localhost:1883 or ssl://localhost:8883
mqtt:openhab_srv.url=tcp://192.168.2.35:1883
Optional. Client id (max 23 chars) to use when connecting to the broker.
If not provided a default one is generated.
mqtt:openhab_srv.clientId=openhab_srv_client
Optional. User id to authenticate with the broker.
mqtt:.user=
Optional. Password to authenticate with the broker.
#mqtt:.pwd=
Optional. Set the quality of service level for sending messages to this broker.
Possible values are 0 (Deliver at most once),1 (Deliver at least once) or 2
(Deliver exactly once). Defaults to 0.
mqtt:openhab_srv.qos=1
Optional. True or false. Defines if the broker should retain the messages sent to
it. Defaults to false.
mqtt:openhab_srv.retain=true
Optional. True or false. Defines if messages are published asynchronously or
synchronously. Defaults to true.
mqtt:openhab_srv.async=false
Optional. Defines the last will and testament that is sent when this client goes offline
Format: topic:message:qos:retained
#mqtt:.lwt=
Wo liegt der Fehler ???
Im voraus Vielen Dank für Eure Hilfe
Tino
