Its difficult to read but this is what is received :
{ “command” : “C:\bat\screensaver.bat”, “args”: “” , “path”: “C:\bat” , “user”: “”, “visible”: false, “fallback”: false }
Is there something i need to do differently to allow this? Ive tried with writing three (3) backwardslashes but still only 1 is being sent.
Since a single backslash () is used to indicate a special character (e.g \t is a tab character) you need to use two (\) to indicate you want a literal backslash. This, if you want two literal backslashes, each one needs to be escaped, so you would need four backslashes where you want two. Try:
