waspie
(scott dee)
1
Am I doing this wrong or am I misunderstanding how this is supposed to work?
I have an MQTT item setup with the new binding but it’s accepting values outside the min/max.
Type number : nurTemp "Nursery Temperature" [ stateTopic="/garage/nursery/nurTMP",min=-1, max=100 ]
vzorglub
(Vincent Regaud)
2
@David_Graeff
Is he misinterpreting the docs?
Min/Max is not defined for the number channel, only for the dimmer channel. That changes with an upcoming feature change only.
waspie
(scott dee)
4
@David_Graeff
I’m running the latest snapshot and this appears to be working as desired now. Can you confirm that this was remedied?
mix/max was fixed with OH 2.5M1 already, I believe. I don’t trust the snapshots atm.
