After update to 1.8 RC I get this error from Mqttitude Binding
2016-01-09 22:42:35.637 [ERROR] [b.m.internal.MqttitudeConsumer] - Unable to calculate relative location for Presence_Elias_PhoneMqtt as there is no lat/lon configured for ‘home’
2016-01-09 22:42:35.674 [ERROR] [b.m.internal.MqttitudeConsumer] - Unable to calculate relative location for Presence_Oliver_PhoneMqtt as there is no lat/lon configured for ‘home’
2016-01-09 22:42:35.736 [ERROR] [b.m.internal.MqttitudeConsumer] - Unable to calculate relative location for Presence_Mike_PhoneMqtt as there is no lat/lon configured for ‘home’
The Mqttitude binding code itself wasn’t changed since 1.7, but that’s not proof there isn’t some other 1.8-related issue. In the meantime, are you sure that the openHAB server is in fact reading the exact openhab.cfg file that contains those lines?
I’m having issues with OwntTracks and OpenHAB, and maybe there is a relation with this issue.
Info:
broker mosquitto
OwnTracks for Android version 0.5.23. Can’t set the Topic in the menus
“Share” is selected with my “work” waypoint (the only Waypoint i’ve set)
i receive the publish with mymqtt and i don’t see any publish message to a topic/subtopic referring to the word ‘event’ or ‘waypoint’
Here is my OpenHAB log:
2016-03-07 13:10:17.496 [DEBUG] [.m.internal.MqttitudeActivator] - Mqttitude binding has been started.
2016-03-07 13:10:17.549 [DEBUG] [.b.m.internal.MqttitudeBinding] - Registering Mqttitude consumer for owntracks/myuser/CelLG (on mosquitto)
2016-03-07 13:10:17.554 [DEBUG] [.b.m.internal.MqttitudeBinding] - Registering Mqttitude consumer for owntracks/myuser/CelLG/event (on mosquitto)
2016-03-07 13:10:17.558 [TRACE] [b.m.internal.MqttitudeConsumer] - Message received on topic owntracks/myuser/CelLG: {"_type":"location","lon":-XX.XXXX478,"tid":"LG","t":"u","acc":30,"tst":1457362884,"lat":-XX.XXXX332}
2016-03-07 13:10:18.458 [TRACE] [b.m.internal.MqttitudeConsumer] - Checking item LG_work...
2016-03-07 13:10:18.460 [ERROR] [b.m.internal.MqttitudeConsumer] - Unable to calculate relative location for LG_work as there is no lat/lon configured for 'home'
2016-03-07 13:10:18.462 [DEBUG] [.b.m.internal.MqttitudeBinding] - Activating Mqttitude binding
2016-03-07 13:11:51.315 [TRACE] [b.m.internal.MqttitudeConsumer] - Message received on topic owntracks/myuser/CelLG: {"_type":"location","lon":-XX.XXXX427,"tid":"LG","t":"u","acc":30,"tst":1457363511,"lat":-XX.XXXX316}
2016-03-07 13:11:51.348 [TRACE] [b.m.internal.MqttitudeConsumer] - Checking item LG_work...
2016-03-07 13:11:51.350 [ERROR] [b.m.internal.MqttitudeConsumer] - Unable to calculate relative location for LG_work as there is no lat/lon configured for 'home'
2016-03-07 13:15:21.334 [TRACE] [b.m.internal.MqttitudeConsumer] - Message received on topic owntracks/myuser/CelLG: {"_type":"location","lon":-XX.XXXX596,"tid":"LG","t":"u","acc":30,"tst":1457363721,"lat":-XX.XXXX325}
2016-03-07 13:15:21.369 [TRACE] [b.m.internal.MqttitudeConsumer] - Checking item LG_work...
2016-03-07 13:15:21.372 [ERROR] [b.m.internal.MqttitudeConsumer] - Unable to calculate relative location for LG_work as there is no lat/lon configured for 'home'
hi everyone,
i think my config is working now, and i really don’t know if it is 100% ok.
I mean, i still have some doubts, …
could it be possible that an Item “loses updates” (or something similar?) and then different icons (light bulbs, shields, etc) of my items turns into “disabled mode” ? (i mean, fro example shield icon in gray color, light icon next to switches off…)
is there a timeout?
I’m sorry but i can’t figure out the when and how it happens; so i don’t know how to put it into words to search for this issue i have…still investigating…
