Dear all,
I am able to pubblish successfully a message with the command
mosquitto_pub -t "mentorage/device/alert" -m "ON"
because mosquitto_sub -t "mentorage/device/alert"
receives the message properly
but with the item
Switch MQTT_Test "Testing..." { mqtt="<[broker:mentorage/device/alert:state:default], >[broker:mentorage/device/alert:command:*:default]" }
nothing seems to happen
The broker is broker=<broker>.url=tcp://localhost:1883
In the log I receive
2018-11-29 18:06:55.666 [ERROR] [ng.mqtt.internal.MqttEventBusBinding] - Could not create event bus command subscriber: Configuration 'broker=<broker>.url=tcp://localhost:1883:mentorage/device/alert/fall:command:default' is not a valid inbound configuration: Configuration requires 4 or 5 parameters separated by ':'
but I commented out the line commandSubscribeTopic in mqtt-eventbus.cfg
I receive
2018-11-29 18:06:55.635 [INFO ] [penhab.io.transport.mqtt.MqttService] - MQTT Service initialization completed.
2018-11-29 18:06:55.639 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection ‘’
as well
Someone can help me?
Thank you
Dev
