Does anyone know how to reset the meter for multi channel devices? I specifically have two zw132 devices (ZW132 v2) and the current setup in the database resets channel 2 but channel 0 and 1 are not reset.
I’ve added the following to the XML and added it to the JAR file to test it but it doesn’t seem to do anything. I did delete the item and rediscover it to make sure it had the latest definition.
<channel id="meter_reset1" typeId="meter_reset">
<label>Reset Meter</label>
<properties>
<property name="binding:*:OnOffType">COMMAND_CLASS_METER:1;reset=true</property>
</properties>
</channel>
According to @ccheng-aeotec all three endpoints should have a meter_reset and they should reset each channel appropriately.
Am I missing something?
BTW, once I figure this out, I will update the database correctly but I didn’t want to make a bunch of edits while I am testing this.
