Thanks a ton for that. Really great. I hope it gets merged in the coming 2.5 release or maybe in the coming milestone. Fingers crossed.
Thanks I would do that today.
Actually, I see that the part of the documentation that describes the configuration is missing. Iâve created a github issue on the topic. The old wiki documentation of ideAlarm that describes the configuration has not yet been migrated to the new documentation.
Excited about getting ideAlarm going - I think I am almost there, but using the Sitemap via the OpenHab iPhone app, the system wonât go to Arm status when I toggle one of the two arming modes.
Iâve checked and rechecked correct object locations, persistence, map files, parsed configuration.py through python buddy, etc.
The items report via the App sitemap:
Z1 open sections 1
Z1 Arming Mode: Disarmed
Z1 Status: Normal
in my logs the most suspicious thing I see is:
2020-02-17 09:38:04.983 [INFO ] [me.core.service.AbstractWatchService] - Loading script âpython/community/idealarm/idealarm.pyâ
2020-02-17 09:38:04.987 [DEBUG] [ipt.internal.ScriptEngineManagerImpl] - Added ScriptEngine for language âpyâ with identifier: file:/etc/openhab2/automation/jsr223/python/community/idealarm/idealarm.py
2020-02-17 09:38:11.042 [ERROR] [ipt.internal.ScriptEngineManagerImpl] - Error during evaluation of script âfile:/etc/openhab2/automation/jsr223/python/community/idealarm/idealarm.pyâ: ImportError: No module named idealarm in at line number 2
Sounds like the files are not copied to the right directories. What do you see returned fromâŠ
tree ${OPENHAB_CONF}/automation/lib/python/community/idealarm
BTW, if you were to use the beta Jython bundle, this library would be installed for you. Core and community helper libraries are included in the bundle.
I get this:
/etc/openhab2/automation/lib/python/community/idealarm
âââ init.py
OK⊠so the file is in the right place, but the account that runs OH canât see the file. Check the permissions?
ls -al ${OPENHAB_CONF}/automation/lib/python/community/idealarm
drwxrwxr-x 2 openhab openhab 4096 Feb 17 10:44 .
drwxrwxr-x 3 openhab openhab 4096 Feb 17 10:38 âŠ
-rw-rw-r-- 1 openhab openhab 27061 Feb 12 10:17 init.py
OK⊠the account has permissions to it. Do you have any other scripts that use the helper libraries and are they working properly? The last thing I can think of is to check sys.path. Put this into a test scriptâŠ
from core.log import logging, LOG_PREFIX#, log_traceback
LOG = logging.getLogger("{}.TEST".format(LOG_PREFIX))
import sys
if hasattr(sys.version_info, "major"):
LOG.warn("Jython version [{}.{}.{}.{}]".format(sys.version_info.major, sys.version_info.minor, sys.version_info.micro, sys.version_info.releaselevel))
LOG.warn("Jython version [{}]\n".format(sys.version))
LOG.warn("sys.path [{}]".format(sys.path))
One other thought⊠do you have a community package? Whatâs inâŠ
(should be an empty __init__.py
Just did a chmod to 777 and that seemed to do it, watching the rules fire now, sitemap disappeared in meantime - Thanks for your help! I think I am almost there !!
Oh and regarding the community package - I DID have that missing earlier, but repaired it - good idea
And - YES - it works nicely!!!
