Im new to openhab.
I would like to combine ZWave Binding + MQTT Binding in one item string.
Zwave in Habmin is running. I see Channels.
Mqtt binding is working also.
I startet with Danfoss Zwave Radiator.
This Zwave Node have a Battery Channel.I would like to publish this Battery Cahnnel with MQTT.
So I created a Items file in /Items
Number Wohnzimmer_Esstisch_Thermostat_Battery "Wohnzimmer Esstisch Thermostat Battery Status [%d %%]" {channel="zwave:device:7fe0340b:node4:battery-level", mqtt=">[mosquitto:openHAB/Main-OH/zwave/thermostat/Wohnzimmer_Esstisch_Thermostat_Battery:state:default]"}
This is not working.
Heres the LOG:
10:11:28.972 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'mqtt-zwave.items'
10:11:28.984 [ERROR] [el.item.internal.GenericItemProvider] - Binding configuration of type 'mqtt' of item 'Wohnzimmer_Esstisch_Thermostat_Battery' could not be parsed correctly.
org.eclipse.smarthome.model.item.BindingConfigParseException: Configuration 'mosquitto:openHAB/Main-OH/zwave/thermostat/Wohnzimmer_Esstisch_Thermostat_Battery' is not a valid outbound configuration: Configuration requires 5 parameters separated by ':'
at org.openhab.core.binding.internal.BindingConfigReaderDelegate.processBindingConfiguration(BindingConfigReaderDelegate.java:50)[176:org.openhab.core.compat1x:2.1.0]
at org.eclipse.smarthome.model.item.internal.GenericItemProvider.internalDispatchBindings(GenericItemProvider.java:325)[123:org.eclipse.smarthome.model.item:0.9.0.b5]
at org.eclipse.smarthome.model.item.internal.GenericItemProvider.internalDispatchBindings(GenericItemProvider.java:297)[123:org.eclipse.smarthome.model.item:0.9.0.b5]
at org.eclipse.smarthome.model.item.internal.GenericItemProvider.processBindingConfigsFromModel(GenericItemProvider.java:182)[123:org.eclipse.smarthome.model.item:0.9.0.b5]
at org.eclipse.smarthome.model.item.internal.GenericItemProvider.modelChanged(GenericItemProvider.java:367)[123:org.eclipse.smarthome.model.item:0.9.0.b5]
at org.eclipse.smarthome.model.core.internal.ModelRepositoryImpl.notifyListeners(ModelRepositoryImpl.java:286)[122:org.eclipse.smarthome.model.core:0.9.0.b5]
at org.eclipse.smarthome.model.core.internal.ModelRepositoryImpl.addOrRefreshModel(ModelRepositoryImpl.java:136)[122:org.eclipse.smarthome.model.core:0.9.0.b5]
at org.eclipse.smarthome.model.core.internal.folder.FolderObserver.checkFile(FolderObserver.java:234)[122:org.eclipse.smarthome.model.core:0.9.0.b5]
at org.eclipse.smarthome.model.core.internal.folder.FolderObserver.processWatchEvent(FolderObserver.java:297)[122:org.eclipse.smarthome.model.core:0.9.0.b5]
at org.eclipse.smarthome.core.service.WatchQueueReader.run(WatchQueueReader.java:206)[98:org.eclipse.smarthome.core:0.9.0.b5]
at java.lang.Thread.run(Thread.java:748)[:1.8.0_152]
Can someone give me a hint.
thx
LG
