mstormi
(Markus Storm)
January 9, 2026, 8:47pm
1
Does anyone know how to create a multicolored chart line? i.e. color of a section depends on the y range the value is in.
Like for a temperature curve that starts violet-blue below/at zero and gets green-yellow-orange-red when it’s getting warmer.
I read Apache eCharts supports it but cannot get it to work yet.
Alternatively, a bar type chart with differently colored bars?
Nico_Bunk
(Nico Bunk)
January 9, 2026, 11:26pm
2
I did it like this:
label: Tellers
period: D
sidebar: true
slots:
dataZoom: []
grid:
- component: oh-chart-grid
containLabel: false
show: true
legend:
- component: oh-chart-legend
show: true
top: bottom
series:
- component: oh-time-series
color: "#56a653"
gridIndex: 0
item: Dak_Inverter_Deye1_Deye1_voltage
name: Deye1 AC Voltage
type: line
xAxisIndex: 0
yAxisIndex: 5
visualMap:
- component: oh-chart-visualmap
pieces:
- color: transparent
lt: 200
- color: "#f58c8c"
ge: 200
lt: 207
- color: "#f5d68c"
ge: 207
lt: 220
- color: "#56a653"
ge: 220
lt: 240
- color: "#f5d68c"
ge: 240
lt: 253
- color: "#f58c8c"
ge: 253
seriesIndex: 0
show: false
mstormi
(Markus Storm)
January 10, 2026, 4:29am
3
didn’t work for me.
Where’s the link from the visual map to the item’s chart line?
I have several lines and don’t want this to apply to all of them, obviously.
Nico_Bunk:
seriesIndex: 0
I have not tested it, but “seriesIndex: 0” should define first line in chart.
Output from AI:
slots:
visualMap:
type: continuous
orient: vertical
right: 10
top: center
min: -10
max: 30
calculable: true
# IMPORTANT: 0 corresponds to the first series (e.g. outside temperature)
seriesIndex: 0
inRange:
color:
- "#313695" # Kalt (Blau)
- "#4575b4"
- "#abd9e9"
- "#ffffbf" # Mild (Gelb)
- "#fdae61"
- "#f46d43"
- "#d73027" # Warm (Rot)
. . .or if you want to define the range:
visualMap:
type: piecewise
orient: vertical
right: 10
top: center
seriesIndex: 0
# Here you can define your own areas:
pieces:
- lt: 0
color: "#0000FF"
label: Frost (unter 0°C)
- gte: 0
lt: 15
color: "#00BFFF"
label: Kühl (0-15°C)
- gte: 15
lt: 25
color: "#FFA500"
label: Angenehm (15-25°C)
- gte: 25
color: "#FF0000"
label: Heiß (über 25°C)
I can test this later today.
Later today = Now
For me it works (openHAB 5.1.1)
Or with own ranges:
mstormi
(Markus Storm)
January 10, 2026, 11:38am
6
that worked once I used seriesIndex to apply to my temp line
very cool, thanks both of you.
PS: how to get the range legend over to the left?
mstormi:
orient: vertical
right: 10
top: center
