Hi Rich,
I think multiple cases just don’t work.
The following code works for h = 23, 11, 12, 17, and 22, so for lines that have a command, but it does not for h = 5:
rule "Test"
Time cron "*/30 * * * * ?" or
System started
logInfo ("Test", "0")
val int h = 5
switch h
case 0,
case 1,
case 2,
case 3,
case 4,
case 5,
case 23: logInfo ("Test", "night")
case 6,
case 7,
case 8,
case 9,
case 10,
case 11: logInfo ("Test", "morning")
case 12: logInfo ("Test", "noon")
case 13,
case 14,
case 15,
case 16,
case 17: logInfo ("Test", "afternoon")
case 18,
case 19,
case 20,
case 21,
case 22: logInfo ("Test", "evening")
And this is, what is logged:
2019-03-06 10:11:43.877 [INFO ] [o.model.script.openHAB started] - System started
2019-03-06 10:12:10.330 [INFO ] [org.openhab.model.script.Test ] - 0
2019-03-06 10:12:10.373 [ERROR] [m.r.internal.engine.RuleEngine] - Error during the execution of startup rule 'Test': Ambiguous methods [protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateAssignment(org.eclipse.xtext.xbase.XAssignment,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateBlockExpression(org.eclipse.xtext.xbase.XBlockExpression,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateBooleanLiteral(org.eclipse.xtext.xbase.XBooleanLiteral,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateCastedExpression(org.eclipse.xtext.xbase.XCastedExpression,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateClosure(org.eclipse.xtext.xbase.XClosure,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateConstructorCall(org.eclipse.xtext.xbase.XConstructorCall,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected org.eclipse.xtext.xbase.interpreter.IEvaluationResult org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateDoWhileExpression(org.eclipse.xtext.xbase.XDoWhileExpression,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateForLoopExpression(org.eclipse.xtext.xbase.XForLoopExpression,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateIfExpression(org.eclipse.xtext.xbase.XIfExpression,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateInstanceOf(org.eclipse.xtext.xbase.XInstanceOfExpression,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateMemberFeatureCall(org.eclipse.xtext.xbase.XMemberFeatureCall,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateNullLiteral(org.eclipse.xtext.xbase.XNullLiteral,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateNumberLiteral(org.eclipse.xtext.xbase.XNumberLiteral,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateReturnExpression(org.eclipse.xtext.xbase.XReturnExpression,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateStringLiteral(org.eclipse.xtext.xbase.XStringLiteral,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateSwitchExpression(org.eclipse.xtext.xbase.XSwitchExpression,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateThrowExpression(org.eclipse.xtext.xbase.XThrowExpression,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateTryCatchFinallyExpression(org.eclipse.xtext.xbase.XTryCatchFinallyExpression,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateTypeLiteral(org.eclipse.xtext.xbase.XTypeLiteral,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateVariableDeclaration(org.eclipse.xtext.xbase.XVariableDeclaration,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateWhileExpression(org.eclipse.xtext.xbase.XWhileExpression,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator)] for params [null, org.eclipse.xtext.xbase.interpreter.impl.DefaultEvaluationContext@347130cd, org.eclipse.xtext.util.CancelIndicator$1@42bc36f]
2019-03-06 10:12:22.373 [INFO ] [org.openhab.model.script.Test ] - 0
2019-03-06 10:12:22.378 [ERROR] [.o.m.r.i.engine.ExecuteRuleJob] - Error during the execution of rule Test
java.lang.IllegalStateException: Ambiguous methods [protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateAssignment(org.eclipse.xtext.xbase.XAssignment,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateBlockExpression(org.eclipse.xtext.xbase.XBlockExpression,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateBooleanLiteral(org.eclipse.xtext.xbase.XBooleanLiteral,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateCastedExpression(org.eclipse.xtext.xbase.XCastedExpression,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateClosure(org.eclipse.xtext.xbase.XClosure,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateConstructorCall(org.eclipse.xtext.xbase.XConstructorCall,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected org.eclipse.xtext.xbase.interpreter.IEvaluationResult org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateDoWhileExpression(org.eclipse.xtext.xbase.XDoWhileExpression,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateForLoopExpression(org.eclipse.xtext.xbase.XForLoopExpression,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateIfExpression(org.eclipse.xtext.xbase.XIfExpression,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateInstanceOf(org.eclipse.xtext.xbase.XInstanceOfExpression,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateMemberFeatureCall(org.eclipse.xtext.xbase.XMemberFeatureCall,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateNullLiteral(org.eclipse.xtext.xbase.XNullLiteral,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateNumberLiteral(org.eclipse.xtext.xbase.XNumberLiteral,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateReturnExpression(org.eclipse.xtext.xbase.XReturnExpression,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateStringLiteral(org.eclipse.xtext.xbase.XStringLiteral,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateSwitchExpression(org.eclipse.xtext.xbase.XSwitchExpression,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateThrowExpression(org.eclipse.xtext.xbase.XThrowExpression,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateTryCatchFinallyExpression(org.eclipse.xtext.xbase.XTryCatchFinallyExpression,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateTypeLiteral(org.eclipse.xtext.xbase.XTypeLiteral,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateVariableDeclaration(org.eclipse.xtext.xbase.XVariableDeclaration,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator), protected java.lang.Object org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateWhileExpression(org.eclipse.xtext.xbase.XWhileExpression,org.eclipse.xtext.xbase.interpreter.IEvaluationContext,org.eclipse.xtext.util.CancelIndicator)] for params [null, org.eclipse.xtext.xbase.interpreter.impl.DefaultEvaluationContext@28504489, org.eclipse.xtext.util.CancelIndicator$1@42bc36f]
at org.eclipse.xtext.util.PolymorphicDispatcher.handleAmbigousMethods(PolymorphicDispatcher.java:308) ~[na:na]
at org.eclipse.xtext.util.PolymorphicDispatcher.invoke(PolymorphicDispatcher.java:283) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:218) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateSwitchExpression(XbaseInterpreter.java:360) ~[na:na]
at sun.reflect.GeneratedMethodAccessor96.invoke(Unknown Source) ~[na:na]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[na:1.8.0_151]
at java.lang.reflect.Method.invoke(Method.java:498) ~[na:1.8.0_151]
at org.eclipse.xtext.util.PolymorphicDispatcher.invoke(PolymorphicDispatcher.java:291) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._evaluateBlockExpression(XbaseInterpreter.java:321) ~[na:na]
at sun.reflect.GeneratedMethodAccessor54.invoke(Unknown Source) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:204) ~[na:na]
at org.openhab.model.script.internal.engine.ScriptImpl.execute(ScriptImpl.java:59) ~[na:na]
at org.openhab.model.rule.internal.engine.ExecuteRuleJob.execute(ExecuteRuleJob.java:55) ~[na:na]
at org.quartz.core.JobRunShell.run(JobRunShell.java:213) [quartz-all-2.1.7.jar:na]
at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:557) [quartz-all-2.1.7.jar:na]
2019-03-06 10:12:32.719 [INFO ] [org.openhab.model.script.Test ] - 0
Best regards,
Stefano
