Should the following work in OH2?
Switch F2_Bed_Light "Bed Light" <light> (F2, Lighting) {enocean="{id=00:29:1B:09, channel=A, eep=F6:02:01}",
enocean="{id=00:29:DD:01, channel=A, eep=F6:02:01}"}
By “work” I mean: F2_Bed_Light
gets switched on or off by either one of the EnOcean wall switches. At the moment, only the second one seems to “work”.
Background: I use MQTT/Event-Bus to handle the commands generated. The first EnOcean switch doesn’t publicise any MQTT information, but the second one does. I realise I could have separate Switch
es for each EnOcean thing, but the above seems to me to be simpler and clearer.
Steve
