I setup a door bell sensor. This works fine and now I want to setup some rules on it.
Rules are also working fine so far but I wanted to be able to check whether the button was pushed more than once. For example if I would setup a mobile phone push notification every time the button is pressed I would receive 3 or 4 messages for the same person standing in front of my door.
Is it possible to ignore the second till x event for a specified period of time (for example one minute)? The rule event should happen only once.
This is my current rule:
import org.openhab.core.library.types.*
import org.openhab.core.persistence.*
import org.openhab.model.script.actions.*
import org.joda.time.*
rule "door bell"
Item hm_klingel received update ON
logInfo("Door Bell","Somebody pushed the bell button.")
var Timer lockklingel = null
rule "door bell"
if(lockklingel == null) { // if not blocked
lockklingel = createTimer(now.plusMinutes(2), [ | // create block
lockklingel = null // release block later
logInfo("Door Bell","Somebody pushed the bell button.") // do whatever immediately
You only missed one bracket. Just let me post the correct code for all users reading this thread later:
rule "door bell"
